Topic: Looking for a tiny GPS module + antenna (Read 5813 times) previous topic - next topic
0miker0
I was just wondering if anyone here can recommend a tiny GPS module + antenna module. I'm currently using the EM-411 module from here: http://dx.com/p/em-411-gps-engine-board-module-with-sirf-star-iii-chipset-80037?item=1 but it's a little larger then what I was expecting and it doesnt seem to work that great unless it is very close to a window.
Mike
Docedison
That is typical of most GPS receivers. I  have 2 in front of me now connected to 2 different Arduino's and position data shifts in about a 300 meter circle centered on my apartment, depending on the number of birds (satellites) that are above me. The more sat's the better my position accuracy. I watch the Altitude data tell me that my house is moving about 30 meters up and down as well. Fortunately I don't need to know my position... I know where I live, The GPS receivers were the easiest way to get accurate time without either using the internet NTP server or the NIST WWVB service from Boulder Co. as it isn't available really except at sunrise and sunset due to propagation issues with the extremely long wave (60 KHz) used to transmit the time codes. The reason for the receiver issues that force you to be near a window is simple most building materials are opaque to the 1.7 GHz signal transmitted by the satellites and thus the signal to your receiver is a great deal weaker than it needs to be for proper operation Storms also cause similar effects due to the water vapor in the storm clouds. My receivers are two, a U-Blox-6 (35 X 35 mm) I bought from Electrodragon and a Skylabs SKM53 ( 20 X 27) mm I bought for $26.00 from Ebay. What you might do is buy a receiver with a separate antenna there is usually 3 to 5 meters of cable from antenna to receiver or you can put a 3 conductor cable on your receiver, put the receiver in a water tight enclosure and remote it... 5 meters of 3 conductor shielded cable would work very well. The third option is to use a transmitter and a controller (Mini-Pro?) to remote the receiver wirelessly. I hope this helps.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
florinc
Docedison
Actually no, when you consider the breakout board to interconnect it. Those little ~1mm spaced pads are hard to solder to and the soldered wires if used, are fragile. There are also 4 ground connections that should be soldered to a ground plane for proper operation of the receiver so a small piece of PCB material 20 X 32 mm would allow you to do a minimum job of wiring it up. There are usually on the breakout boards bypassing for the power supply and standard 2.54 mm pin spacings for male or female headers (preferred) or just plain wiring is ok too although I really prefer to bypass things like that... just because it's really cheap insurance and good engineering  practice too, besides they draw no power and add little additional bulk to the project. Inexpensive too. I bought 130 - 150 10 ea 1 to 470 uF caps from Electrodragon for less than $2.00 same amount and money for an assortment of disc capacitors from 10pF to 100 nF and I use a lot of the .01, .05 and mostly the .1uF caps. Like I said really cheap insurance also materials for more projects.
Bob
--> WA7EMS <--
