Loading...
Pages: [1]   Go Down
Author Topic: VirtualWire send multiple variables at once  (Read 288 times)
Offline Offline
Newbie
View Profile
I am using VirtualWire library (http://www.open.com.au/mikem/arduino/VirtualWire.pdf) and RF transmitter/reciver to communicate between two arduinos.
There is function in this library to send data:
vw_send((uint8_t *)msg, strlen(msg));
I need to send data like this:
string timestamp;
float voltage;
float current;
float power;
DataToSend = timestamp + "," + voltage + "," + current + "," + power;
for example: "2012.10.13, 4.59, 0.36, 1.65";
Is there any solution for this problem?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Of course. The sprintf() function comes to mind.
Logged
Offline Offline
Newbie
View Profile
It was said somewher on the forum, that sprintf() does not accept floats.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
And it says elsewhere on the forum different workarounds.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Can you post some links/examples please?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The usual methods of printing floats involve either printing the whole number and the fractional portion separately, or using dtostrf() to convert the float to a (unformatted) string.
Logged
Finland
Offline Offline
Sr. Member
Arduino rocks
View Profile
It would be more efficent to send the data in binary form:
Code:
  const char * timestamp = "2012.10.13";
  float voltage = 4.59;
  float current = 0.36;
  float power = 1.65;
  int size_of_float = sizeof(float);
  int size_of_timestamp = strlen(timestamp);
  uint8_t buffer[size_of_timestamp+size_of_float*3];
  void *p = buffer;
  memcpy(p, (void *)timestamp, size_of_timestamp);
  p += size_of_timestamp;
  memcpy(p, (void *)&voltage, size_of_float);
  p += size_of_float;
  memcpy(p, (void *)&current, size_of_float);
  p += size_of_float;
  memcpy(p, (void *)&power, size_of_float);
  vw_send(buffer, sizeof(buffer));
And you could also send the timestamp as a 32bit integer instead of a string.
Logged
Värmland, Sweden
Offline Offline
Full Member
View Profile
It's worth taking into account that VirtualWire has a send limit of 27 bytes per transmission so it's possible that you will have to split your data.
Logged
Pages: [1]   Go Up
Print
Jump to:
