Loading...
Pages: [1]   Go Down
Author Topic: What is the ICSP pins for?  (Read 5470 times)
Philippines
Offline Offline
Jr. Member
Graduating Computer Engineering Student
View Profile
WWW
Could anyone tell me what are the ICSP pins for? smiley
is this an input pin? for expansion of output pins? thanks!
- Migs
Logged
Don't stop Learning.
Arduino Projects:
SMS-Based LED Matrix Display
http://youtu.be/WVhDr5CNxwE
California
Offline Offline
God Member
View Profile
WWW
Mostly ICSP it is a AVRtiny programming header for the Arduino consisting of MOSI, MISO, SCK, RESET, VCC, GND.  It is often refered to as an SPI (Serial Peripheral Interface) which could be considered an "expansion" of the output, but really, you are slaving the output device to the master of the SPI bus.
So, Master Input and Output depends on the master smiley-wink
Logged
Philippines
Offline Offline
Jr. Member
View Profile
WWW
Oh. I see. I've read somewhere that it's also used to burn the bootloader to the ATmega Chip. Is this true?
Quote
does this mean i can use it to cascade two shields? i'm having problems stacking two shields together (GSM Shield and LED matrix shield) because of pin connections.
- Migs
Logged
Arduino Projects:
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
With reference to the AVR chips themselves, they are they way you program the chips in-system.  You connect the programmer to these six pins somehow - usually over a ribbon cable with two 6 pin IDC headers but you can just use some jumpers too.  The programmer can then send the production file (elf file) to the chip.  You can get the production file from the Arduino software or from Atmel Studio.
This guy is going from the 6-pin cable to jumpers to the breadboard.  I would have just used a IDC socket.  But otherwise, this is how you do it.  This bypasses the Arduino for a bare $0.80-$3.00 controller which you can add to any project without having a dangling Arduino, but you have to buy the programmer for $35.
http://allaboutee.com/2011/05/11/how-to-program-an-avr-microcontroller/
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
California
Offline Offline
God Member
View Profile
WWW
Quote
Absolutely, Nick Gammon has a slick sketch that takes care of this:
http://www.gammon.com.au/forum/?id=11635
Quote
Only if the two shields have micro-controller to slave (unlikely).  With two complicated devices, I would recommend an I2C setup:
http://www.gammon.com.au/forum/?id=10896
If you can get your specifics down, I am pretty sure Nick can help you (He is a moderator here...).
Logged
Philippines
Offline Offline
Jr. Member
View Profile
WWW
thanks for the great tip guys. smiley just new to the Arduino Community. Lots more to it that just straight up prototyping. haha. getting a hang of it though. thanks again. smiley
Logged
Arduino Projects:
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The clue is in the acronym  - ICSP = In-Circuit Serial Programming
Logged
Pages: [1]   Go Up
Print
Jump to:
