Pages: 1 [2]   Go Down
Author Topic: Serial.print messing with Timer Interrupts  (Read 1429 times)
20 LEDs are enough
Today I checked with a DSO: ISR duration is almost exactly 123 microseconds for each and every period the DSO captured. I tried to trigger on >130 microsecond hi pulses but got not trigger condition. --> no pulse exceeds 130 microseconds
Then I triggered on >950 microseconds low pulses --> it does not trigger --> seems it does not drop any interrupt.
I conclude that this ***looks*** like a bug in my code and the ISR seems to work fine. However this would imply that adding the prints somehow makes my code glitch. Very strange.
« Last Edit: November 09, 2012, 03:20:12 pm by Udo Klein » Logged
Melbourne, Australia
Shannon Member
Lua rocks!
I can't really explain it.
If you were doing the Serial prints inside an ISR, yes it would be explained. But you don't appear to be doing that.
BTW I would use the variable "max" with caution as max is defined in Arduino.h:
#define max(a,b) ((a)>(b)?(a):(b))
Without the parentheses you get away with it, but it is a bit dubious.
Perhaps you are altering some global variable you forgot about?
Dallas
Online Online
Shannon Member
Processor?
20 LEDs are enough
Finally I found it out. It is a very subtle bug in MsTimer2:
ISR(TIMER2_OVF_vect) {
#if defined (__AVR_ATmega168__) || defined (__AVR_ATmega48__) || defined (__AVR_ATmega88__) || defined (__AVR_ATmega328P__) || (__AVR_ATmega1280__)
TCNT2 = MsTimer2::tcnt2;
#elif defined (__AVR_ATmega128__)
#elif defined (__AVR_ATmega8__)
#endif
MsTimer2::_overflow();
If you remove the macros and only look at mega168 then you get
What is going on here? The library runs timer2 with a prescaler of 64. Thus the timer will tick with 250 kHz. So every 250 ticks an interrupt must be triggered to achieve the desired rate of one interrupt per millisecond. Instead of using CTC mode the library uses "normal mode". Thus the timer will process 256 ticks between to interrupts but it should use only 250. In order to compensate for this the ISR will advance TCNT2 immediately to the value of MsTimer2::tcnt2; which happens to be 6.
If TCNT2 == 0 at the start of the ISR, then of course this is equivalent to skipping 6 ticks. The result is the desired delay. However if TCNT2 > 0 at the start of the ISR, then it will skip less ticks. In the most extreme case TCNT2 == 255 setting it to 6 would result in 249 additional ticks instead of 6 skipped ticks.
But why is this an issue if I use Serial.print??? In order to find out I disassembled my compiled code. Here is what I found:
 22c: 1f 92       push r1 cycles: 2 total:  2
 22e: 0f 92       push r0 cycles: 2 total:  4
 230: 0f b6       in r0, 0x3f ; 63 cycles: 1 total:  5
 232: 0f 92       push r0 cycles: 2 total:  7
 234: 11 24       eor r1, r1 cycles: 1 total:  8
 236: 2f 93       push r18 cycles: 2 total: 10
 238: 3f 93       push r19 cycles: 2 total: 12
 23a: 4f 93       push r20 cycles: 2 total: 14
 23c: 5f 93       push r21 cycles: 2 total: 16
 23e: 6f 93       push r22 cycles: 2 total: 18
 240: 7f 93       push r23 cycles: 2 total: 20
 242: 8f 93       push r24 cycles: 2 total: 22
 244: 9f 93       push r25 cycles: 2 total: 24
 246: af 93       push r26 cycles: 2 total: 26
 248: bf 93       push r27 cycles: 2 total: 28
 24a: ef 93       push r30 cycles: 2 total: 30
 24c: ff 93       push r31 cycles: 2 total: 32
 24e: 80 91 1b 01 lds r24, 0x011B cycles: 2 total: 34
 252: 90 91 1c 01 lds r25, 0x011C cycles: 2 total: 36
 256: 80 93 b2 00 sts 0x00B2, r24 cycles: 2 total: 38
#endif
 25a: 0e 94 d7 00 call 0x1ae ; 0x1ae <_ZN8MsTimer29_overflowEv>
So MsTimer2 takes 38 cpu cycles + ISR trigger overhead till it can set TCNT2. So everything that delays the MsTimer2 ISR for more than 24 cpu cycles will drag it down.
Looking into the serial ISR I find
000004b8 <__vector_19>:
#elif defined(USART0_UDRE_vect)
ISR(USART0_UDRE_vect)
#elif defined(USART_UDRE_vect)
ISR(USART_UDRE_vect)
#endif
 4b8: 1f 92       push r1 cycles: 2 total:  2
 4ba: 0f 92       push r0 cycles: 2 total:  4
 4bc: 0f b6       in r0, 0x3f ; 63 cycles: 1 total:  5
 4be: 0f 92       push r0 cycles: 2 total:  7
 4c0: 11 24       eor r1, r1 cycles: 1 total:  8
 4c2: 2f 93       push r18 cycles: 2 total: 10
 4c4: 3f 93       push r19 cycles: 2 total: 12
 4c6: 5f 93       push r21 cycles: 2 total: 14
 4c8: 6f 93       push r22 cycles: 2 total: 16
 4ca: 7f 93       push r23 cycles: 2 total: 18
 4cc: 8f 93       push r24 cycles: 2 total: 20
 4ce: 9f 93       push r25 cycles: 2 total: 22
 4d0: af 93       push r26 cycles: 2 total: 24
 4d2: bf 93       push r27 cycles: 2 total: 26
 4d4: ef 93       push r30 cycles: 2 total: 28
 4d6: ff 93       push r31 cycles: 2 total: 30
  if (tx_buffer.head == tx_buffer.tail) {
 4d8: 20 91 a1 01 lds r18, 0x01A1 cycles: 2 total: 32
 4dc: 30 91 a2 01 lds r19, 0x01A2 cycles: 2 total: 34
 4e0: 80 91 a3 01 lds r24, 0x01A3 cycles: 2 total: 36
 4e4: 90 91 a4 01 lds r25, 0x01A4 cycles: 2 total: 38
 4e8: 28 17       cp r18, r24 cycles: 1 total: 39
 4ea: 39 07       cpc r19, r25 cycles: 1 total: 40
 4ec: 31 f4       brne .+12     ; 0x4fa <__vector_19+0x42> cycles: 1-2 total: 41-42
// Buffer empty, so disable interrupts
#if defined(UCSR0B)
    cbi(UCSR0B, UDRIE0);
 4ee: 80 91 c1 00 lds r24, 0x00C1
 4f2: 8f 7d       andi r24, 0xDF ; 223
 4f4: 80 93 c1 00 sts 0x00C1, r24
 4f8: 16 c0       rjmp .+44     ; 0x526 <__vector_19+0x6e>
    cbi(UCSRB, UDRIE);
#endif
  else {
    // There is more data in the output buffer. Send the next byte
    unsigned char c = tx_buffer.buffer[tx_buffer.tail];
 4fa: e0 91 a3 01 lds r30, 0x01A3 cycles: 2 total: 44
 4fe: f0 91 a4 01 lds r31, 0x01A4 cycles: 2 total: 46
 502: ef 59       subi r30, 0x9F ; 159 cycles: 1 total: 47
 504: fe 4f       sbci r31, 0xFE ; 254 cycles: 1 total: 48
 506: 20 81       ld r18, Z cycles: 1 total: 49
    tx_buffer.tail = (tx_buffer.tail + 1) % SERIAL_BUFFER_SIZE;
 508: 80 91 a3 01 lds r24, 0x01A3 cycles: 2 total: 51
 50c: 90 91 a4 01 lds r25, 0x01A4 cycles: 2 total: 53
 510: 01 96       adiw r24, 0x01 ; 1 cycles: 2 total: 55
 512: 60 e4       ldi r22, 0x40 ; 64 cycles: 1 total: 56
 514: 70 e0       ldi r23, 0x00 ; 0 cycles: 1 total: 57
 516: 0e 94 f0 03 call 0x7e0 ; 0x7e0 <__divmodhi4> cycles: 2 total: 59 + time for the subroutine
 51a: 90 93 a4 01 sts 0x01A4, r25 cycles: 2 total: 61
 51e: 80 93 a3 01 sts 0x01A3, r24 cycles: 2 total: 63
  #if defined(UDR0)
    UDR0 = c;
 522: 20 93 c6 00 sts 0x00C6, r18 cycles: 2 total: 65
    UDR = c;
  #else
    #error UDR not defined
  #endif
 526: ff 91       pop r31 cycles: 2 total: 67
 528: ef 91       pop r30 cycles: 2 total: 69
 52a: bf 91       pop r27 cycles: 2 total: 71
 52c: af 91       pop r26 cycles: 2 total: 73
 52e: 9f 91       pop r25 cycles: 2 total: 75
 530: 8f 91       pop r24 cycles: 2 total: 77
 532: 7f 91       pop r23 cycles: 2 total: 79
 534: 6f 91       pop r22 cycles: 2 total: 81
 536: 5f 91       pop r21 cycles: 2 total: 83
 538: 3f 91       pop r19 cycles: 2 total: 85
 53a: 2f 91       pop r18 cycles: 2 total: 87
 53c: 0f 90       pop r0 cycles: 2 total: 89
 53e: 0f be       out 0x3f, r0 ; 63 cycles: 1 total: 90
 540: 0f 90       pop r0 cycles: 2 total: 92
 542: 1f 90       pop r1 cycles: 2 total: 94
 544: 18 95       reti cycles: 4 total: 98
Obviously 98 is greater than 24 and I did not even count the cycles used inside of "call   0x7e0   ; 0x7e0 <__divmodhi4>".
In order to verify my hypthesis I replace MsTimer2 with the following code:
ISR(TIMER2_COMPA_vect) {
    process_one_sample();
void initTimer2() {
    // Timer 2 CTC mode, prescaler 64
    TCCR2B = (1<<WGM22) | (1<<CS22);
    TCCR2A = (1<<WGM21);
    // 249 + 1 == 250 == 250 000 / 1000 ==  (16 000 000 / 64) / 1000
    OCR2A = 249;
    // enable Timer 2 interrupts
    TIMSK2 = (1<<OCIE2A);
Yeah!!! Now only 30ppm deviation. This is within the expected tolerance of the crystal. Bug understood and fixed smiley
I will contact the author of the library to fix this for the whole community.
One afterthought: I do not like to have ISR driven serial output. But now matter if this is a good idea or not, the library is full with code like
int i = (unsigned int)(buffer->head + 1) % SERIAL_BUFFER_SIZE;
Since the Arduino does have no hardware division this is very costly both in terms of CPU and memory. A much better way to wrap a counter is:
int i = (unsigned int)(buffer->head);
i = i<SERIAL_BUFFER_SIZE-1? i+1: 0;
« Last Edit: November 09, 2012, 02:43:44 pm by Udo Klein » Logged
Dallas
Online Online
Shannon Member
Thank for the follow-up and amazingly thorough analysis!
Shannon Member
Lua rocks!
Interesting! Here, you mean?
void MsTimer2::_overflow() {
count += 1;
if (count >= msecs && !overflowing) {
overflowing = 1;
count = 0;
(*func)();
overflowing = 0;
So it relies on not missing those "overflow" ticks? I see what you mean.
20 LEDs are enough
No. It relies on skipping 6 cycles by setting TCNT2 to 6. However this implies that TCNT2 would be 0 which is not necessarily the case. It never misses any of the 1ms ticks. It is only sometimes some cycles to late. As I said: this is very subtle and it took me ~4 weeks to figure this one out.
To be more precise: the bug is:
Actually the underlying issue is to use "normal" mode instead of CTC mode.
« Last Edit: November 09, 2012, 02:49:41 pm by Udo Klein » Logged
Shannon Member
Lua rocks!
As calculated here?
tcnt2 = 256 - (int)((float)F_CPU * 0.001 / prescaler);
Hmm. I see. Well I don't like fiddling with counters anyway, I believe they "belong" to the timer, especially if it is running.
Shannon Member
Lua rocks!
Well done, BTW.
It didn't occur to me to look in the library, nor did it occur to me that the library-writer would use a method like that which relied on things happening "just right".
20 LEDs are enough
This is another issue. Compare
to
C is case sensitive. The first line sets tcnt2 in the  MsTimer2 namespace. The second line changes the timer register. So he does not rely on things happening just right. He just created a race condition. This happens even to the best smiley-wink The tricky part is to find and eliminate them.
Thanks for the compliments. I am proud of this analysis as well. Now the way is paved to the most resilent DIY DCF77 clock ever. The whole story will take probably 4 months of blogging smiley
« Last Edit: November 09, 2012, 03:20:47 pm by Udo Klein » Logged
Shannon Member
Lua rocks!
I understand about the variables, I was just wondering how you got TCNT2  = 6;
Since this:
256 - (16000000 * 0.001 / 64) == 6
I presume the prescaler was 64.
BTW on this page here I set up Timer2 to generate an interrupt at exactly 1 mS intervals. It didn't take a lot of code, and since the timer itself counted to 1 mS you didn't have this overflow issue.
20 LEDs are enough
As I already wrote: I have code for this:
void initTimer2() {
    OCR2A = 249;
However I would have preferred the library approach. That way I would not have to explain to my readers how the timers actually work. Creating a recursively phase locked DCF clock will be more than enough to swallow.
Shannon Member
Lua rocks!
... this is very subtle and it took me ~4 weeks to figure this one out.
Once again, my compliments on not only solving it, but attempting to solve it in the first place.
Many people would say "near enough is good enough" or "it must be a processor bug" but you stuck with it, had confidence in your ability to find it, and did so. It gives one confidence that your other code will be equally well-written. smiley
20 LEDs are enough
In the last 20 years I have seen only one processor but that caused a program to fail. So in doubt I always assume code is to blame. What made this one particular difficult was the length of my ISR. So thought that the ISR might be to blame as ISRs have a high chance to cause trouble. Thus I was ~3 weeks on the wrong track.
Pages: 1 [2]   Go Up
