Loading...
Pages: 1 [2]   Go Down
Author Topic: Why arduino can fry?  (Read 1190 times)
Offline Offline
Edison Member
View Profile
Quote
I've accidentally shorted outputs and even inserted the 328P backwards
You are in good company there, smiley.
People screaming about "damages" here simply have no idea what they are talking about; or don't understand the datasheet when they quoted it as support.
Some OEMs went so far to specify shortcircuit current.
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Quote
Hey! Look people - we've got our very own troll.
Logged
Per Arduino ad Astra
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
FWIW... I've accidentally shorted outputs and even inserted the 328P backwards... never hurt the chip (yet).
Damaged components don't always fail immediately after being damaged.
I'm bookmarking this as a great example of "the pot calling the kettle black."
Logged
www.cmiyc.com - A guide to being an Enginerd
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Low (dc) resistance isn't the issue: you can actually short your avr's pins without damaging them
You've done this?
I don't think you can claim that - appearing to still work is not the same as undamaged - overloading the output transistors causes local overheating and perhaps electromigration on the chip which will first degrade then disable the transistors in that area - the reliability and robustness is impaired before obvious/gross loss of function is seen.  Once degraded the risk of future failure without warning is increased.  Manufacturers put values in the abs max spec that are just conservative enough (they don't want to be sued for being unfit-for-purpose, yet want to look as good as possible compared to the competition...  I would always recommend staying below them by a sensible margin.
Quote
Of course, in reality the datasheet specs MUST be adhered to or else the chip WILL get ruined sooner or later.
A more positive spin is obey the abs max constraints so you end up with about strange unexplaned failures in the future!
You
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Most (in my experience) "newer" Microprocessors will withstand an accidental short once or twice... to ground, even occasionally instead of once or twice. Most All Microprocessors will survive a short to Vcc once or twice but likely never occasionally and No microprocessor will survive shorting to a positive supply greater than Vcc to less than ground (Negative voltages) without a resistor big enough to limit the current to what the input protection diodes can withstand. Some types of micro's are more robust than others and for some obvious reasons the choice of the Atmel product was a wise one. The '328's are a hardy chip family. I've never yet read here that shorting an "output" pin to ground will destroy that pin or the processor instantly or even soon. I've read many times of the per pin current limits and infrequently of "other" types of shorts. I've NO DOUBT  that a long term short... 5 - 10 minutes would cause enough internal heating to begin the "electromigration" mentioned and even cause the device to fail. That's one major issue with mos devices and overheating from wrong type loads is the major failure event for Mosfet power transistors (Bipolar devices fail in a similar manner from "second breakdown" which is a place on the "overloaded" transistor die that has a crystalline defect, the defect gets hot and fails causing more area's near the failure to fail until the device fails utterly. If the same transistor is never operated at or above it's rated max current these types of failures are most rare. I used to test silicon power transistors for that issue by measuring the C-E resistance... it should be a near open circuit > 5 megs. Measurements less than 50K were a danger flag for me and I replaced those parts. With a mosfet there is no easy way to look for electromigration unless it be in the gate capacitance... The defect in my experience is mainly damage to the gate structure (The oxide layer under the gate metallization) and the damage is really unnoticeable until the device fails although my high power fet use was limited to RF power amplifiers. I used many power mosfets but the ones that failed were the ones that regularly were operated at 100 + Deg C (failed fans or air filters clogged). All of the above mentioned conditions are "Over the Top" and are the exception rather than the rule.... There have been a lot of "My Pin puts out 1.5V... Why? types of questions but not many in which the poster reported failure because of the error...
Did I "Fry" my Uno?, I accidentally connected a pin to Vcc or ground or I connected my servo power to a pin on the Uno because I wanted to turn off the motor...
but rarely reports that the device utterly failed. Common sense is the key here, A short should be avoided if at all possible but isn't cause for failure or ALL of us would be seeing more messages to that effect. Great topic for "Trolling" though... I suspect someone got stood up for "Saturday Night" and is revealing his/her frustration here...
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Be Excellent To Each Other
Offline Offline
God Member
View Profile
You can absolutely kill an Arduino or the ATMega328 or a pin or two.  Many people have done this.  I have heard many more stories of people killing pins than killing a whole 328, though.  I've overheated my Arduino's regulator a few times and it has shut itself down which is better than I can say about TLC5940 chips.
If you damage the chip, a replacement is about $5 for the chip itself, with the bootloader included, so it really isn't the end of the world.  All hail the DIP package, pop it out, pop a new one in.  Couldn't be any easier.
If you never kill a chip you haven't been trying hard enough.  Seriously...  Everyone kills a few chips.
« Last Edit: October 13, 2012, 11:22:35 pm by JoeN » Logged
Anaheim CA.
Offline Offline
Edison Member
View Profile
Yeah I've killed a few myself. My only point was that it isn't quite as easy as just an occasional intermittent short. It's the real abuse, shorts to higher voltage or other "sins" that really kill the parts. I agree about replacing a $5.00 chip and your statement about anyone who hasn't... but from my experience an accident once or twice isn't as bad as it seems I have 6 Arduino's; Uno's, Mega's and Pro mini's and I have yet to lose one, perhaps more from luck than anything else and I DON'T recommend that shorts be not considered bad for the processor, Not at all. Just that IMO and experience that most aren't immediately fatal unless you involve the protection diodes, that is always fatal unless current limited and still not a great idea. I participate to the best of my limited ability here every day and although there are many "blown" chips the cause isn't generally connecting an LED W/O a limiting resistor or a relay that requires a hundred mA to operate. This "feature" was my factoid about the designers having chosen well. I've popped a lot of old Mos devices due to shorts and made a whole gang of similar mistakes in the 40+ years I've worked in this field... some because of ignorance and some from poorly designed parts and I guess I've been extremely lucky with mine. I have yet however to loose a chip on an Arduino board. As an afterthought it wouldn't have hurt much to put a 470R resistor in series with each I/O pin... wouldn't help the protection diode issue but it would sure protect the ports from overloads or shorts and IMO if 470R is an issue then the design needs to be re-evaluated... IMO Strictly
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
