Topic: Servo range problem (Read 1 time) previous topic - next topic
robhammer
Hello!
I encounter a little problem playing with my arduino board.
I am just trying to have one servo going in two positions.
The servo is a Futaba s3151 (doc here: http://www.servocity.com/html/s3151_sport_ball_bearing.html)
The Arduino Board is powered by USB, and the servo by a Laboratory Power Suply in 5V, 200mA max. Grounds are connected.
It is working perfectly fine in the mid range (30° to 160° aprox.), or (775ms pulse to 2177ms pulse)
But outside this range, the servo is de-activated.
I switched to the Servo -> Sweep example to eliminate software problem.
The servo is sweeping from 30° to 160°, the a littel pause de-activated, the sweeping  from 160 to 30, the a littel pause de-activated .....
I change to a small 9g servo, and it is working fine the whole range.
Does anyone allready had a problem like this?
Thanks you,
Robin
zoomkat
Per the below specs, the servo might not have a full 180 deg operating range. Your 5v 200ma max power supply will probably not be adequate for the servo to do much.
Control System: +Pulse Width Control 1520usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.21sec/60 degrees at no load
Operating Speed (6.0V): 0.19sec/60 degrees at no load
Stall Torque (4.8V): 43 oz/in. (3.1kg.cm)
Stall Torque (6.0V): 56 oz/in. (4.0kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
Current Drain (4.8V): 7.2mA/idle
Current Drain (6.0V): 8mA/idle
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: All Nylon Gears
Connector Wire Length: 12"
Dimensions: 1.6" x 0.8"x 1.4" (41 x 20 x 36mm)
Weight: 1.5oz. (43g)
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
MarkT
Something more like 0.5 to 1.5A might be better for that servo, given its high torque.
You can calculate theoretical load currents from the other specifications for a DC motor (geared or not).  current x voltage = power, torque x angular velocity = power.
Thus current = torque x angular velocity / voltage.
Here torque at 6V = 56 in.lb = 0.41 Nm - the max torque figure, roughly represents stall or near-stall condition
angular velocity at 6V = 5.5 rad/s   (0.19s for 60 degrees).
Therefore theoretical current at that torque is 0.41 x 5.5 / 6.0 = 0.38A not allowing for any electrical or frictional losses.  1A is a good
guestimate I think.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
