Topic: 12 UV leds arduino (Read 2094 times) previous topic - next topic
initzero
Hello all !!!!
How can i get 12 UV leds running on 5v arduino ?????
12-LED UV Flashlight Silver (3xAAA)
http://dx.com/p/12-led-uv-flashlight-silver-3xaaa-4014
What resitor do i need for serial conection????
thank you for the help...
johnwasser
Measure the voltage across an LED when the flashlight is lit.  Call that V.
Disconnect one of the LED leads and measure the current through that diode when the flashlight is lit.  Call that C.
Subtract V from 5 to get the voltage across the dropping resistor.  Divide that voltage by the current C (in Amps) to get Ohms.  Use one resistor per diode.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Boffin1
And be very careful with UV LEDs, I was temporarily blinded for a couple of hours by them without even looking into them on purpose !
45 years of editing projects with a knife and soldering iron, then I found Arduino !
initzero
Thank you guys for the replay!!!
johnwasser
i already desolder the leds from the tourch.
I m going to try to hook up them all.
Thanks for the tip!!!
Boffin1
Thanks for the warning!!!!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
