Topic: Poor serial performance when sending data from RaspberryPi to Arduino (Read 16845 times) previous topic - next topic
mrnick1234567
Oct 14, 2012, 01:45 am Last Edit: Oct 14, 2012, 01:47 am by mrnick1234567 Reason: 1
Hello,
I wondered if anyone could give me some help on why my serial performance is very slow. I have an Arduino driving an LED matrix, receiving data from a Raspberry Pi using Python and pyserial. The serial data is sent over a USB cable plugged between the Pi and Arduino.
A sketch on the Arduino listens for bytes, one control byte, then 1536 pixel data bytes. (The LED matrix is 1024 RGB pixels at 4 bit colour. I pack two 4 bit values into each byte, so each RGB pixel is 1.5 bytes. Therefore an entire frame is sent in 1024 pixels x 1.5 bytes per pixel = 1536 bytes.)
If my maths is right... Running at 115200 baud, I make that roughly 14400bytes/s - enough that I should see a maximum of 9 frames per second. However I'm only seeing roughly two frames per second. Even at 230400 baud things are 2 or 3 fps.
Any ideas appreciated!
Here is the Python send code:
Code: [Select]
import serial
from time import sleep
#setup serial port
port = "/dev/ttyACM0"
ser = serial.Serial(port, 230400, timeout=1)
sleep(1) #wait for serial
#fill screen with white then black
loop=0
while (loop < 100):
    #draw totally white frame (all bytes value 11111111)
    #send control byte: 1 = draw frame
    ser.write(chr(1))
    #send screen data - 2 pixels sent in 3 bytes. 1024 pixels in total = 512 loops of 3 bytes (1536 bytes total)
    c=0
    while (c < 512):
        ser.write(chr(255))
        ser.write(chr(255))
        ser.write(chr(255))
        c=c+1
    #draw totally black frame (all bytes value 00000000)
    ser.write(chr(1))
    #send screen data - 2 pixels sent over 3 bytes. 1024 pixels in total = 512 loops of 3 bytes (1536 bytes total)
    c=0
    while (c < 512):
        ser.write(chr(255))
        ser.write(chr(255))
        ser.write(chr(255))
        c=c+1
    loop=loop+1
And here is the Arduino receive code.
Code: [Select]
#include "RGBmatrixPanel.h" //3rd party matrix driver
//define pins
#define A   5
#define B   4
#define C   3
#define D   2
#define CLK 10
#define LAT 9
#define OE  7
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, true);
  Serial.begin(230400);
  matrix.begin();
  byte incomingByte = 0;
  if (Serial.available() > 0) {  //if > 1 get 1st byte which is control byte
    incomingByte = Serial.read();
    //if control byte is 1, draw frame
    switch ( int(incomingByte) ) {
    case 1:
      drawScreen();
    default:
      Serial.println("unknown cmd");
void drawScreen() {
  //Total bytes to receive is 1536
  byte x = 0;
  byte y = 0;
  byte r = 0;
  byte g = 0;
  byte b = 0;
  byte data = 0;
  while (y < 32 ) {
    if (Serial.available() >= 3) { //read 3 bytes (2 pixels)
      //read 1st byte and split into nibbles
      data = byte (Serial.read());
      r = data & B00001111;
      g = data >> 4;
      //read 2nd byte and split into nibbles
      b = data & B00001111;
      //draw pixel1
      matrix.drawPixel(x, y, matrix.Color444(r,g,b));
      //next pixel
      x++;
      r = data >> 4;
      //read 3rd byte and split into nibbles
      g = data & B00001111;
      b = data >> 4;
      //draw pixel2
      //next pixel
      if (x == 31){
        x=0;
        y++;
      else {
        x++;
  matrix.swapBuffers(false);
PaulS
Quote
It isn't. Each bytes requires sending 10 bits, not 8.
Code: [Select]
Why are you performing this cast? The switch function is perfectly happy with a byte as the argument.
You're receiver is not waiting for three bytes. It is looping through the while loop many times before the third byte arrives. Are you monitoring what the Arduino sends back? I'm guessing that there are a lot of messages being sent back. That is why your receive rate is so low.
mrnick1234567
Hi Paul, thanks for taking the time to reply.
I was unaware serial required 10 bits per character, OK so that knocks the maximum frame rate down a little. The cast to Int in the switch statement was there as I didn't know switch could handle bytes, I'll take it out.
How would you suggest the receiver code waits for the 3 bytes, I wasn't sure what else it could do other than loop round waiting for data. Is that very inefficient?
As for monitoring what the receiver sends back, there is actually nothing being sent back. I stripped out all serialprint lines I had in there for debugging as I thought that might be the cause of the issue.
Cheers
Nick
PaulS
Quote
Code: [Select]
while(Serial.available() < 3)
   // Do nothing
Quote
Yes, very. The alternative is to simply deal with data as it arrives, storing each piece until you have enough to proceed. Then use that data, and reset the array index to start storing again.
mrnick1234567
Thanks again for the pointers Paul, I've tweaked my Arduino code (see below)
I've been experimenting with different baud rates and timing the Arduino function that receives the serial data from the Raspberry Pi. At both 115200 and 230400 baud there is no difference in the time it takes to receive and process a frame of data (1536 bytes). It's about 390 milliseconds either way.
This seems strange, so I wonder if something other than the baud rate is slowing things down.
Commenting out anything to do with the LED matrix drawing routines in the Arduino code made very little difference (10-20 milliseconds) so I know they're not the issue.
The idle python editor on the RaspberryPi also seemed to slow things down. Running the python sender program from the command prompt was quicker and got the 390ms results above.
I'd be interested to know if there any other ways I could squeeze some more performance out of the Arduino code? Is there anything obvious I'm missing ?
Thanks
Nick
Tweaked Arduino code:
Code: [Select]
//define pins
#define A   5
#define B   4
#define C   3
#define D   2
#define CLK 10
#define LAT 9
#define OE  7
  matrix.begin();
  if (Serial.available() > 0) {  //if data, get 1st byte which is a control byte that sets what to do
    case 1:
      drawScreen();
    default:
      Serial.println("unknown control command");
void drawScreen() {
  //Receiving 32x32 pixels = 1024 pixels. Each pixel is 3x4 bit values, so each pixel = 1.5 bytes. Total bytes to receive is 1536
  byte x = 0; //screen x
  byte y = 0; //screen y
  byte r = 0; //red
  byte g = 0; //green
  byte b = 0; //blue
  byte data = 0; //incoming byte
  unsigned startTime= millis();
  while (y < 32 ) {
   //wait for 3 bytes of data
    while (Serial.available() < 3) {
       //do nothing
    //read 1st byte and split into 2 lots of 4 bits, (red and green)
    g = data >> 4;
    //read 2nd byte - b and r of next pixel
    //draw pixel1
   //inc for next pixel
    x++;
    r = data >> 4;
    //read 3rd byte, g and b
    b = data >> 4;
    //draw pixel2
    //inc for next pixel or reset if x at end of row
    if (x == 31){
      x=0;
      y++;
    else {
      x++;
  //print time it took
  Serial.println(millis() - startTime);
  //when all data received, swap buffers and show screen
robtillaart
#5
Oct 20, 2012, 05:10 pm Last Edit: Oct 20, 2012, 05:13 pm by robtillaart Reason: 1
Quote
That means that the other code - on arduino or on raspberry side - is blocking performance.
Be aware that python is an interpreted language,
small bug in arduino code:
unsigned startTime = millis();  should be   unsigned long
Can you post the Raspberry code?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
mrnick1234567
Hi Rob, yes that was what I was thinking. The Raspberry Pi code is in first post if you want to take a look. I\ve noticed it slows down considerably with some operations - e.g. using reading numpy arrays for screen data.
Let me know what you think.
robtillaart
I missed the first post, sorry.
Looking at the python code it just pumps in all data and the arduino is probably overflown with data.
You should add some sort of handshake so that the arduino confirms the receive after every 3 bytes (== 2 RGB pixels).
If that ACKnowledge is received the python program spits the next 3 bytes .
That way you at least synchronize the producer and consumer.
Furthermore there should be some kind of synchronization at the start of the stream.
<idea>
why not make a tuple <x,y,r,g,b> to allow you to set a random pixel on the Arduino screen?
protocol would look like
RP -> A: <x,y,r,g,b>
A -> RP: <ACK>
</idea>
Rob Tillaart
mrnick1234567
Hey Rob,
Thanks for the ideas. Yeah it does just pump a full frame of data out, which is what I need to draw a whole screen of pixels at once (e.g. for example to display a series of frames).
When you say the Arduino is possibly being overwhelmed with data... I don't see any data missing on the frames, so it's not like bytes are being lost. I'd be interested to know how some kind of data overload would manifest itself as slow performance and no data get lost in the process.
I didn't write in in any ACK logic in as yet, as I thought that by adding more traffic things would slow down even more.
I do already have another routine as you suggest that just sets certain pixels and this does run much faster. It's just these full frames I'm having difficulty with.
robtillaart
You could also implement a horizontal line of the same color to speed things up
  e.g. <x,y, len, r,g,b> it is a sort of run length compression.
as this introduces new types of datapackets / tuples there would be a need for an id as first byte in the packet
<1,x,y,r,g,b> = setpixel
<2,x1,y1,x2,y2,r,g,b> = draw any line => look for bresenham
<3,x,y,radius,r,g, b> = circle
<4,x,y,x,y,r,g,b> = square
<5,r,g,b> = floodfill whole screen
etc
Rob Tillaart
Papa G
You didn't mention it so I want to make sure, did you modify /etc/inittab and /boot/cmdline.txt to prevent other processes using /dev/ttyAMA0?
edit: sorry, I see you're using a USB port. Never mind.
Papa G
robtillaart's suggestions are good, but may I make a few more?
The Serial class only takes strings and buffers as input. Strings, like tuples, are immutable, so building arbitrary data packets would be done by concatenation rather than insertion. A bytearray might make more sense as you can write to indices and slices of a bytearray and Serial treats it like a buffer.
I added the concept of bytearrays to your code:
Code: [Select]
import serial
#setup serial port
for l in range(100): #draw totally white frame (all bytes value 11111111)
    ser.write("\x01")   #send control byte: 1 = draw frame
                        #1024 pixels in total = 512 loops of 3 bytes (1536 bytes total)
    white = bytearray([255, 255, 255])
    for c in range(512):
        ser.write(white)
    black = bytearray([0, 0, 0])
        ser.write(black)
Then, to create a custom packet like robtillaart suggested:
Code: [Select]
h = 1 #packet header
x = 0x13 #x coordinate
y = 0x2f #y coordinate
r = 0xc #red value
g = 0x4 #green value
b = 0xe #blue value
packet = bytearray([h, x, y, r, g, b]) #build packet
packet[3:6] = [12, 10, 3] #write new r, g, b values
Grumpy_Mike
The serial data rate is not maintained when going through a USB converter. The USB transfers data in batches or frames.
Also try upping the thread priority in the python code to give it more time before Linux steals some.
mrnick1234567
Thanks for all the suggestions Rob and PapaG... implementing a packet structure seems like a nice way to go.
Mike, I'll try upping the priority and see how it goes.
At the moment running functions that plot LED by LED in a packet of (x,y,r,g,b) seem to overwhelm the Arduino's serial buffer more often than not. Sending an ACK per frame slows things down too much. E.g. when plotting 100 LED's (less than 1/4 the screen) with an ACK per packet it drops the frame rate to 3 or 4 frames per second. Not sure the best way around this. I think I might try and set up something that sends a 'pause' command if the buffer get's near 128bytes full.
Grumpy_Mike
Quote
That is known as Xon / Xoff handshaking.
