Topic: pgm_read_byte doesn't work (Read 5846 times) previous topic - next topic
darknails
Hi, I want to use the flash memory of my Arduino Nano 168, but somehow it gives strange results.
Here is the code:
const prog_uint8_t BitMap[8] = {   // store in program memory to save RAM
        B10000000,
        B00000000,
        B00000000,
        B00000000,
        B00000000,
        B00000000,
        B00000000,
        B00000000,
  Serial.print(BitMap[0]);
  Serial.print("    ");
  Serial.print(pgm_read_byte (&BitMap[0]));
  Serial.print("    ");
The values BitMapp[0] and pgm_read_byte (&BitMap[0]) are different.
BitMapp[0] is 128 (correct), but pgm_read_byte (&BitMap[0]) gives 144 and sometimes different depending on where i put the print command.
And why would one need pgm_read_byte at all. Why not just use BitMapp[0]?
thanks..
nickgammon
The way your array is defined appears to give strange results. This modified version works, and note that only the progmem access works, not the direct access.
byte PROGMEM BitMap  [8] = {  22, 33, 44, 55, 66, 77, 88, 99 };
 for (int i = 0; i < 8; i++)
   Serial.print(BitMap[i]);
   Serial.print("    ");
   Serial.print(pgm_read_byte (&BitMap[i]));
   Serial.println ();
 while (true);  // loop forever
Output:
0    22
0    33
184    44
0    55
0    66
0    77
1    88
0    99
darknails
Thanks, Nick. If I change const to PROGMEM, then it works.
