Loading...
Pages: [1]   Go Down
Author Topic: How to use multiplexer CD74HC4051  (Read 843 times)
Offline Offline
Newbie
View Profile
Hello, I have doubts about how to use the multiplexer CD74HC4051, I need to use it to have both analog inputs to read sensors, as digital outputs to move servos and motors And incidentally also to use digital inputs. I've been looking online and I found three examples for each situation but I not understand.
Code:
  //This for loop is used to scroll through and store the 16 inputs on the FIRST multiplexer
  for (int i=0; i<16; i++)
    //The following 4 commands set the correct logic for the control pins to select the desired input
    //See the Arduino Bitwise AND Reference: http://www.arduino.cc/en/Reference/BitwiseAnd
    //See the Aruino Bitshift Reference: http://www.arduino.cc/en/Reference/Bitshift
    digitalWrite(CONTROL0, (i&15)>>3);
    digitalWrite(CONTROL1, (i&7)>>2);
    digitalWrite(CONTROL2, (i&3)>>1);
    digitalWrite(CONTROL3, (i&1));
    //Read and store the input value at a location in the array
    mux0array[i] = analogRead(0);
  //This for loop is used to scroll through the SECOND multiplexer
    mux1array[i] = analogRead(1);
  //This for loop is used to scroll through the THIRD multiplexer
    mux2array[i] = analogRead(2);
  //The following lines are for printing out results of array0
  Serial.print("mux0array: ");
    Serial.print(mux0array[i]);
    Serial.print("-");
  Serial.println();  //line feed
  //The following lines are for printing out results of array1
  Serial.print("mux1array: ");
    Serial.print(mux1array[i]);
    Serial.print("-");
  //The following lines are for printing out results of array2
  Serial.print("mux2array: ");
    Serial.print(mux2array[i]);
    Serial.print("-");
And
Code:
  //Set MUX control pins to output
  pinMode(CONTROL0, OUTPUT);
  pinMode(CONTROL1, OUTPUT);
  pinMode(CONTROL2, OUTPUT);
  pinMode(CONTROL3, OUTPUT);
  //Since all 3 multiplexers have the same control pins, the one multiplexer data line we want to
  //talk to should be set to output and the other two multiplexer lines should be be 'bypassed' by
  //setting the pins to input
  //Turn on output to digital pin 14 (MUX 0) and turn off the other 2 multiplexer data pins
  pinMode(14, OUTPUT);
  pinMode(15, INPUT);
  pinMode(16, INPUT);
  //This for loop is used to scroll through the FIRST multiplexer
    digitalWrite(CONTROL0, (i&15)>>3); //S3
    digitalWrite(CONTROL1, (i&7)>>2);  //S2
    digitalWrite(CONTROL2, (i&3)>>1);  //S1
    digitalWrite(CONTROL3, (i&1));     //S0
    digitalWrite(14, HIGH);
    delay(100);
    digitalWrite(14, LOW);
    delay(100);
  //Turn on output to digital pin 15 (MUX 1) and turn off the other 2 multiplexer data pins
  pinMode(14, INPUT);
  pinMode(15, OUTPUT);
  pinMode(16, INPUT);
    digitalWrite(15, HIGH);
    delay(100);
    digitalWrite(15, LOW);
    delay(100);
  //Turn on output to digital pin 16 (MUX 2) and turn off the other 2 multiplexer data pins
  pinMode(14, INPUT);
  pinMode(15, INPUT);
  pinMode(16, OUTPUT);
    digitalWrite(16, HIGH);
    delay(100);
    digitalWrite(16, LOW);
    delay(100);
I'm a newbie and I understand some commands but many I do not understand.
Logged
Offline Offline
Edison Member
View Profile
All it takes is to control 3 pins (4 if you don't want to connect anything).
Logged
United Kingdom
Online Online
Faraday Member
View Profile
WWW
I'm not clear on how you have wired the multiplexers and what you are trying to use them for. Please provide a schematic.
Analog multiplexers such as the 4051 are good for multiplexing analog inputs, OK for multiplexing digital inputs, but not really suitable for multiplexing outputs.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Edison Member
View Profile
One issue that may present a challenge is to maintain the output's atomicity.
Logged
Offline Offline
Newbie
View Profile
It would be something like this. But instead of controlling LEDs, if is possible to control servos, and how to program arduino to control each servo independently. Not only I will use all outputs for servos, also I will use for sensors too.
Logged
Offline Offline
Edison Member
View Profile
Some of what you are trying to do is doable with a 4051, others not.
You have to understand that a 4051 is a multiplexer, meaning that at any given point, only one input is connected to the output.
Because of that, a device that requires a continuous signal (a servo) would not work. A device that does not require a continuous signal (led as a visual device) would work.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Do not use a 4051 to drive an output. While there is a tutorial on this it is a stupid thing to do because you need to multiplex for not advantage at all.
You can not drive servo's with a 595 unless you use a software PWM technique which takes a lot of processor time.
Logged
Offline Offline
Newbie
View Profile
So, it is not possible by any multiplexer to control many servos with Arduino?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Yep you got it. Multiplexers and outputs do not go together.
You need shift registers or a chip like the TLC5940 to generate PWM.
Logged
Offline Offline
Edison Member
View Profile
Quote
Anything is possible. But in your design, it is not possible.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Yes you might even give some good or useful advice some time.
Logged
Pages: [1]   Go Up
Print
Jump to:
