Author Topic: halloween project with button  (Read 266 times)
uk
hi all i'm making a halloween project
when a button is pressed on my door which is connected to my arduino i want it to start a sketch for lightning
 i have the sketch but what i want is how to make the sketch run via a button ( code )
any help appreciated
cheers
marko
//    FILE: lightning.pde
//  AUTHOR: Rob Tillaart
//    DATE: 2012-05-08
// PUPROSE: simulate lighning POC
#define BETWEEN 2579
#define DURATION 43
#define TIMES 7
#define LEDPIN 13
unsigned long lastTime = 0;
int waitTime = 0;
  Serial.println("lightning 0.0");
  pinMode(LEDPIN, OUTPUT);
  if (millis() - waitTime > lastTime)  // time for a new flash
    // adjust timing params
    lastTime += waitTime;
    waitTime = random(BETWEEN);
    for (int i=0; i< random(TIMES); i++)
      Serial.println(millis());
      digitalWrite(LEDPIN, HIGH);
      delay(20 + random(DURATION));
      digitalWrite(LEDPIN, LOW);
      delay(10);
  // do other stuff here
« Last Edit: October 14, 2012, 03:14:03 pm by markthespark » Logged
Seattle, WA USA
Online Online
Seattle, WA USA
How is the button connected to the Arduino? Heavy duty cotton thread? Nylon thread? Perhaps using a switch would work better.
So, how is the switch connected to the Arduino? Where are you reading the switch state?
If you connect one side of the switch to a digital pin and the other side to ground, and enable the pullup resistor (digitalWrite(switchPin, HIGH); after the pinMode(switchPin, INPUT); statement), then, digitalRead(switchPin) will return LOW when the switch is pressed.
A simple if statement will then wrap the existing if statement, and cause the effects to begin when the switch is pressed.
uk
the arduino is connected to a 9 volt power supply
but what i want is a momentary swich connected to the arduino to start the sketch
Seattle, WA USA
Online Online
Seattle, WA USA
OK. You can do that.
uk
so where do i go for a sketch for it
Seattle, WA USA
Online Online
Seattle, WA USA
Your favorite text editor. There is a call to set the pin mode, a call to enable the pullup resistor, and a call to read the switch state. I showed all those earlier.
Then, all that is needed is an if statement to enclose the existing code. A total of 6 lines of code.
Try something. It isn't that difficult.
