Topic: PNP Transistor not 'shutting off' when increasing voltage. (Read 4140 times) previous topic - next topic
Inevitableavoidance
I'm trying to multiplex small segments of LED Strips.
I'm sinking using TLC5940's, i'm sourcing using a ULN2803 driving PNP transistors. (BC577)
I started out at 12v, which neatly gave me about 20mA on each rgb led channel.
Since I'm multiplexing I wanted to increase the current going to the LED strips.
I did this by increasing the voltage to 18v.
Now, however, the transistors are not 'shutting down' completely, does anyone know how this happens?
I'm using a 2.5kohm resistor between the base and the ULN2803 outputs.
dhenry
Many things can go wrong. Without a circuit diagram, it is hard to know what.
Grumpy_Mike
Quote
You need pull ups to the +ve and a resistor in series with the base.
Inevitableavoidance
Could you please explain what kind of resistors from where to where that should be?
Grumpy_Mike
Put a 4k7 resistor one end to the base, the other end has a other 4K7 to the +ve and is also connected to the output of the ULN2803.
Values are not critical.
Inevitableavoidance
So then i'd have the the emitter to 18v, a 2k5 from base to the ULN, a 4k7 from the emitter to base, and another 4k7 from the emitter to the ULN?
Runaway Pancake
http://incredulist.blogspot.com/2012/10/high-side-switching.html
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Grumpy_Mike
Inevitableavoidance
Ik hooked up my scope to the collecter and to ground, and noticed something what i consider 'odd'.
When using 12v, I read about 3v when the transistor should be off, and 12v when it should be on.
When using 18v, i read about 12v when the transistor should be off, and 14v when it should be on.
What could this mean?
Inevitableavoidance
Loose the 2K5 and yes.
Without the 2k5 nothing's happening at all..
Docedison
A PNP transistor is effectively a diode from base to emitter ( base cathode ) and pulling too much current from the base WILL destroy the transistor, Short the base to ground and the transistor WILL explode or shut down the power supply, in either case the transistor is toast. ALL PNP transistors need some method of current limiting (A resistor) in the base circuit. If it was an NPN directly pulling the base down, likely the NPN is toast as well.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
Grumpy_Mike
Then you are missunderstand what I was saying. Can you draw what you are doing.
Inevitableavoidance
Bob
To be honest, i don't quite see how this is relevant..?
Also, when not connecting anything to the transistor except for 12v on the emitter and the collector to the 'anode' of the led strips, i measure about 11v from the collector to ground..
Grumpy_Mike
Quote
Transistors are current devices. Do not leave the base floating, the results you see will not make sense.
Inevitableavoidance
#14
Oct 15, 2012, 12:52 am Last Edit: Oct 15, 2012, 12:54 am by Inevitableavoidance Reason: 1
My initial setup was:
Leds
Collector
Base ------2k5-----ULN2803 output
Emitter
18v
What i understood you meant was:
Leds
Collector
Base --- 2k5 --- ULN2803 output
4k7                    |
Emitter ----------4k7
18v
(edited, misdrew something)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
