Topic: SpeakJet output help. (Read 2065 times) previous topic - next topic
swordofnoah
I am using a speakjet ic chip with the arduino duemilanove for speech synthesis and I'm getting some problems from the audio output. I'm using the software serial library and I'm getting no compilation errors. This is how I send out the allophones( is this correct? )
speakJet.println(175);
speakJet.println(179);
My problem is when I connect the pin 18 to a amplifier and speaker, all I get is a high pitched squeal. I have a delay after the print and the delay works fine (it does seem a little short though). I can't see what I've done wrong, can someone help?
swordofnoah
Does anyone know how to answer this?
codlink
Nobody can help with no code or schematic.
//LiNK
hemavathy
Can anyone tell me the capability of interfacing TTS256 with speakjet that is how many words that can speak.someone told that it ll speak 1ly 8 words whether it correct r not can u help me with this
dxw00d
Post links to what you are talking about, if you want help.
hemavathy
I have done the connection as mentioned in this below link and executed the same code.
http://www.sparkfun.com/tutorials/166
But it says only 'Ready' and nothing else
hart
I'm guessing as I can't see your circuit / schematic - but if you are connecting a sound module's output to an amplifier you might need to reduce the gain before going in - I certainly found that to be the case with a circuit I built recently.  Try adding a capacitor and resistor or two to the circuit - e.g.:
soundPin ------ (+)10uF CAP(-) ------ 10k? --+-- 220? ----- GND
                                         AMP-IN
                                        SPEAKER
