Topic: arduino web thermostat controlled with android phone (Read 27296 times) previous topic - next topic
marque
Oct 15, 2012, 11:09 am Last Edit: Nov 10, 2013, 11:26 am by marque Reason: 1
****** Updated version *******
Thermoduino Pro is the Pro version of my first android application "Thermoduino" and is used to control the  temperature in your house from anywhere.  The new version comes with a new arduino sketch which can handle timers which you set can in the app and show extra sensor info like humidity etc.
You need:
1 arduino Mega
1 W5100 ethernet shield
1 DHT 22
1 two channel relay card
some wiring
EEPROMEX  Library
DHT   Library
RTC   Library
some debugging knowledge :D
Android app
Arduino sketch
Please, leave a comment after download / install.
pittom
pittom
dwattel
It would be nice to have a schematic of your arduino.
Not everyone knows how to build your idea.
And do you have the Dutch version on-line as well?
marque
#6
Oct 28, 2012, 06:11 pm Last Edit: Oct 28, 2012, 06:16 pm by marque Reason: 1
I quickly made some schematics. see he first post.
You like the app with dutch text labels? For now its not online, perhaps a future version is multi langual. If i have time i send you a previous version in dutch or you can use my other app that suports custom text labels and has nearly the same funcionality.
http://arduino.cc/forum/index.php/topic,127770.0.html
nikitarrr
Seems to be a nice project....
i am trying to test it but I received a lot of errors...
sketch_oct31a.cpp:24:22: error: EEPROMex.h: No such file or directory
sketch_oct31a.cpp:25:20: error: Avviso.h: No such file or directory
sketch_oct31a.cpp: In function 'void setup()':
sketch_oct31a:141: error: 'EEPROM' was not declared in this scope
sketch_oct31a.cpp: In function 'void loop()':
sketch_oct31a:280: error: 'EEPROM' was not declared in this scope
sketch_oct31a.cpp: In function 'void action(int, EthernetClient)':
sketch_oct31a:422: error: 'EEPROM' was not declared in this scope
sketch_oct31a:459: error: 'EEPROM' was not declared in this scope
Where can I find the above libraries? Please help
Thanks a lot,
marque
the EEPROMex library with thanks to mrTeehttp://arduino.cc/forum/index.php?topic=115587.0
You can delete the line  #include <Avviso.h>
This an libray to send notifications to you phone. I commented out the code it uses but i forgot to remove the include line in the uploaded version. It has some nice function but i removed it because it needs a subscrision to "prowl" or "notifier my android" and because the sketch became to big to fit an arduino uno. More info can be found here: https://github.com/colagrosso/avviso. Whenever i recieve my mega (china post  :( ) i wil us it to let the arduino send a notification when the temperature in my house gets to hot and i can decide to open some windows remotely or close the shutters when its freezing outside.
andrewluck
Looks an interesting project. Do you have schematics?
andrewluck
I think I've found the pieces I ws looking for on other projects.
FigZ
Nice - thanks for sharing
what exactly do the relays hook up to and what do they do?
This could be different for a lot of heating systems, and it is the core of your whole idea.
dtokez
#12
Dec 04, 2012, 05:33 pm Last Edit: Dec 04, 2012, 05:44 pm by dtokez Reason: 1
This looks great, can't wait to try it out!
I'm confused about the relays though, which one does what? I would only need one relay for my boiler?
thanks
dtokez
testing now, but LCD screen is stuck on 'Getting IP'. I have assigned it the same IP that I use in other sketches and same mac address.
With the serial debugging I can see that is also stuck on Getting IP
have you seen this before? I have installed the DHT AND EEEPROM libs, I'm running bare bones with no temp sensors connected but don't think that is the problem?
marque
#14
Dec 05, 2012, 11:40 am Last Edit: Dec 05, 2012, 11:43 am by marque Reason: 1
With one relay you can switch between your current thermostat and the arduino thermostat.
The second thermostat turns on / off your heating system the same way your current thermostat does.
I uploaded some simple schematict in the opening post.
