Topic: arduino web thermostat controlled with android phone (Read 27287 times) previous topic - next topic
Alesz
Hello
Thx Marque for very interesting project (Controler, Somfy, ...) many thx
All your project I easy install and use but with thermostat I have a problem with error look below.
Any idea for reason?
I use: Arduino uno R3, Ethernet Shield W5100, DFRobot LCD Keypad Shield,  DHT22 2x 2 channel 5v relay.
The library  EEPROMEx working if I use a sample.
First error in 142 lines:
""""  Tw = EEPROM.readFloat(address);"""""
thermostat_marque_android.ino: In function 'void setup()':
thermostat_marque_android:142: error: 'EEPROM' was not declared in this scope
thermostat_marque_android.ino: In function 'void loop()':
thermostat_marque_android:281: error: 'EEPROM' was not declared in this scope
thermostat_marque_android.ino: In function 'void action(int, EthernetClient)':
thermostat_marque_android:423: error: 'EEPROM' was not declared in this scope
thermostat_marque_android:460: error: 'EEPROM' was not declared in this scope
thx Marque in advance.
br ale
tkbyd
An idea for anyone building such a system in a region where temperatures go low enough to freeze pipes:
Make it fail-safe. What if your Ardu-stat turns the heat completely off, by malfunction?
Easy to do:
Keep your old thermostat in the circuit. Set it to turn the heading on at, say, 40 deg F.
Wire your Arduino circuits in parallel across your existing thermostat (assuming that your system turns the heat ON when a switch in the thermostat CLOSES).
Now your Arduino can ADD heat to your house, but even if the Arduino is never calling for heat, the old thermostat can step in, save the day, should the temperature fall to 39.
More on Fail Safe Design at...
http://sheepdogguides.com/des1.htm
alvydas001
br ale
same error with Arduino IDE 5.1
with the Arduino IDE 1.0.1 - no errors
marque
New beta version is online.
Find it here: http://forum.arduino.cc//index.php?topic=180344.msg1336692#msg1336692
lmsvvavr
Hi everyone!
I am completely new to this, and chose this as my first project.
Probably should have started with something more simple...
Anyway, this is a bit more that a project, is something that I realy need working...
I bought all the parts, download everything and know I am getting some errors when compiling the sketch.
Highlithed in yellow is the lines I am having problem with...
The first one says:
error: 'DHT22' was not declared in this scope - This should be only to identify the sensor type inside the DHT library.
        However if I include the DHT22 library the error goes away.
Then the next one says:
error: expected primary-expression before ')' token - I don't have a clue how to solve this one...
There is some more, but one at the time... LOL
/*DHT.cpp has an default delay of 250. This makes the system realy slow and must be adjusted to 50 to react faster
  Hardware used:
  Arduino uno
  DHT22 Humidity and Temperature sensor
__________1___     Room Thermostat pin 2
Relay 1___2__/     Heater pin 2
__________3___     Relay 2
__________1___     Mot Connected
Relay 2___2__/     Relay 1
__________3___     Heater pin 1 and Room Thermostat pin 1
#include <LiquidCrystal.h>
#include <Ethernet.h>
#include <HTTPClient.h>
#include <EEPROMEx.h>
#include <SPI.h>
#include <DHT.h>
#define DHTPIN1 (A0)                    // pin connected to temperature sensor
#define DHTPIN2 (A1)                    // optional second temperature sensor
#define DHTTYPE DHT22
DHT dht1(DHTPIN1, DHTTYPE);
DHT dht2(DHTPIN2, DHTTYPE);
const int System =  2;     // pin connected to relay 1
const int Heater =  3;     // pin connected to relay 2
const int Buzzer =  A5;     // pin connected to buzzer
float Tc;               // measured temperature
float Td;               // disired temperature
float h1;
float h2;
float t2;
float Tt;
int softwareversion = 1191;
int address = 0;            // eeprom address
If anyone can help will be much appreciated!
Thank you in advance!
marque
Hi everyone!
The first one says:
  Hardware used:
  Arduino uno
#include <SPI.h>
#include <DHT.h>
float h1;
float h2;
float t2;
float Tt;
You need to download the LiquidCrystal and EEPROMEx library's. but i suggest you use the new beta version. it is easier to install and much more stable, I use it for more than a year now and never had problems.  It doesn't come with the LCD but that's what the phone is for :)
Download it here:
Please let me know if you run into troubles.
lmsvvavr
hi
With the new one I get this:
Arduino: 1.5.4 (Windows XP), Board: "Arduino Uno"
ThermoduinoPro_beta_ino:24: error: 'A10' was not declared in this scope
ThermoduinoPro_beta_ino:24: error: 'DHT22' was not declared in this scope
ThermoduinoPro_beta_ino:31: error: 'A13' was not declared in this scope
ThermoduinoPro_beta_ino.ino: In function 'void setup()':
ThermoduinoPro_beta_ino:981: error: 'A8' was not declared in this scope
ThermoduinoPro_beta_ino:984: error: 'A12' was not declared in this scope
ThermoduinoPro_beta_ino:987: error: 'A14' was not declared in this scope
ThermoduinoPro_beta_ino:995: error: 'class DHT' has no member named 'begin'
ThermoduinoPro_beta_ino.ino: In function 'void loop()':
ThermoduinoPro_beta_ino:1030: error: 'class DHT' has no member named 'readHumidity'
ThermoduinoPro_beta_ino:1031: error: 'class DHT' has no member named 'readTemperature'
marque
hi
The new version is only available for the Arduino mega because of the sketch size. Sorry for that :~
And it looks like you don't have the DHT library installed.
lmsvvavr
ok then
But can you help me with the other one!
And that is the thing, the library is installed...
lmsvvavr
#24
Nov 08, 2013, 12:37 am Last Edit: Nov 08, 2013, 01:03 am by lmsvvavr Reason: 1
Right, finally I have managed to get it working....
Although, your Thermoduino Pro it seems to suit my needs much better... as you can enable profiles and just control more than one system within the app,  just by toggle the tabs at the top! Great work marque...
So I bought 2 arduino mega, and another Ethernet shield...
To build two systems...
Basically I just want to incorporate my actual wireless thermostats(which one is actually faulty...) into my android control panels...
Photo attached...
Now, your Thermoduino Pro says it will expire in January next year... what that really means?
lmsvvavr
#25
Nov 08, 2013, 10:56 pm Last Edit: Nov 08, 2013, 11:00 pm by lmsvvavr Reason: 1
Some feedback about your Thermoduino Pro...
One of my "control panels" is running android 4.0.4... and the app just close down as if a fatal error is encountered...
On the other panel running 4.1.1 it runs just fine... my both phones with 4.1.2 no problem as well...
marque
#26
Nov 10, 2013, 11:11 am Last Edit: Nov 10, 2013, 11:16 am by marque Reason: 1
Good to hear you got it working.
These test version can be use for 3 months only but i will update them before they expire.
How did you connected the app with the arduino? search function, pair function or manually entered the IP?
Did you already used the timer function?
When does the forced close occurs on android 4.0.4? eg. on start up, on tab change, on enter settings?
Do you understand how you can send the extra info like humidity etc.?
Can you send me an screenshot of the working app?
Gr, Maque
lmsvvavr
Hi
Actually I still awaiting for some of the parts. ..
But I have installed the app...
On the tablet where the app is not working,  it does not even start... starts loading and then just says somthing like the app is not responding and it will close. ..
I will be setting the app manually. .. I use static ip on my network. .. so it will be easy do it manually.
I am not sure how to use the timers, nor how to set the extra info... a little help would be great...
I will indeed post the pictures of the app working... I should get the other bits soon, I will then set everything on the bench and will post the results.
Ame90
Hi, I state that I am new in the field Arduino, but I come from the old school Atmel. I would chidere one thing. The project I'm testing on an Arduino Uno. I would understand why I get an error compiling this:
Termostato:1108: error: 'class DateTime' has no member named 'dayOfWeek'
   if (now.dayOfWeek() == 0 || now.dayOfWeek() == 6) {
I would like to figure out how to solve this error. Thanks so much. if you can help ...
