Topic: Analog input timer (Read 673 times) previous topic - next topic
trvslamm
small issue I know one of you can helo me out with very easily. If I want the code below to only work if the analogRead has been less than two for 30 seconds what do i do?
Code: [Select]
if (analogRead(0) < 2) {digitalWrite (LEDpinStat, HIGH);}
johnwasser
Code: [Select]
static unsigned long timerStart = 0;
if (analogRead(0) >= 2)
    timerStart = millis();
if (millis() - timerStart > 30000)
    digitalWrite (LEDpinStat, HIGH);   // A0 has been <2 for 30 seconds or more
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Coding Badly
What you are trying to do is essentially the same as debouncing a push-button.  This should get you started...
Code: [Select]
unsigned long Mark;
void loop( void )
   Mark = millis();
 if ( millis() - Mark >= 30000UL )
   // Do your thing.
