Topic: Counting rpm (Read 4616 times) previous topic - next topic
dhenry
" would use 100K."
Be careful there. The pin's input capacitance is about 7pf. With a 100k resistor, the cut off frequency is about 200khz. For a 10 teeth wheel, that means the shaft cannot rotate more than 20krpm - many dc motors can go that fast.
And if you factor in parasitics, that number is even lower.
This is a case where the resistor should be as low as possible.
gardner
I was suggesting using a 5V zener diode to clip the top of the waveform and the negative part.  Then the resistor can be small - 330R or something, since problematic voltages go through the zener to ground.
If you then feed the resulting waveform into a comparator with the reference voltage at 0.5V or 1V, and you should get a nice clean square wave.
Dyslexicbloke
Thanks for the correction Peter, its always good to learn.
If I knew where the box was I would probably still want to think outside it!
Feel free to be blunt ... Its how I learn.
serbar
Hi.
I made the circuit on the atached file, and collected the following oscilogram.
1. Do you suggest some improvements on this for noise or something else?
2. How can i count this pulses on arduino?
Thanks.
serbar
Sorry for the huge image of the oscilogram...
Some aditional information:
I collected the oscilogram with chanel A at the output of LM 393 and gound, and chanel B (they are superimposed) at input of non inverting input and ground.
Horizontal scale- 1 ms/div
Vertical scale - 5 V/div
The sensor is inductive pick up and has one terminal connected to ground.
By the way, why are the negative pikes smaller than the positive ones?
PS: This is my first circuit with ampops.
Thanks.
serbar
Allready wrote a sketch for this to work, and it works fine. Some noise when i disconnect motor on the op amp but i will study something to avoid this.
Code: [Select]
volatile float npulse=0;
volatile int  freq=0;
volatile int rpm;
  while(!Serial){
  pinMode(2,INPUT);
  digitalWrite(2,HIGH);
  attachInterrupt(1,react,FALLING);
if (freq<1500)
  Serial.println("Frequencia do sinal");
  Serial.println(freq);
  Serial.println("Rot por segundo");
  Serial.println(rpm);
  Serial.println("Rot por minuto");
  Serial.println(rpm*60);
  Serial.println("---------------------------");
  Serial.println("RPM maximo atingido");
  delay(3000);
void react()
  volatile float n2pulse = micros();
  volatile float ndentes=10;
  freq=1000000/(n2pulse-npulse);
  rpm=1000000/(ndentes*(n2pulse-npulse));
  //rpm*=60;
  npulse = n2pulse;
Darshandarshu
Can anyone help me out in finding a inductive sensor that can suit to calculate the rpm of cvt  and it's average rpm is 3800 .considering the temp and other factor like input voltage I need a prefarable sensor .
aarg
A four year old thread... that is a serious necro! Did you see the warning message before you posted?
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
