Topic: Uno Internal Temperature Sensor (Read 3013 times) previous topic - next topic
book_woorm
Has anybody used or played with the on chip internal temperature sensor on the uno. There is reference to it in the 328 and tiny 48 data sheet (section 23.9) which gives some code to directly access the registers, but what about using it alongside the other analog pins on the arduino? If there is code around for doing both in the same sketch then I'm not looking in the right place and would be gratefull for any pointers?
retrolefty
There have been postings on the use of the internal temp sensor from time to time, you just have to search a little. However in my opinion it's a pretty worthless (in my opinion) sensor as the chips internal temperature is going to be more effected by how much current the output pins are having to supply to their external circuitry. So maybe if you are not using any output pins, or they are supplying only minimum and steady value current, it's possible to utilize the sensor somehow. As I recall it requires quite a bit of calibration effort even then.
So first question is what is it that you are expecting to be measuring with the sensor and what will you do with the information from it?
Lefty
RIDDICK
I like to use it for emergency shutdown:
when it is higher than 350K (or so) it pulls down the alarm line... :)
here it showed up before (search words: internal temperature sensor):
http://arduino.cc/forum/index.php/topic,122103.0.html
robtillaart
I used it to get "random" bits from the internal heat source.
see - http://arduino.cc/forum/index.php/topic,38091.0.html -
Rob Tillaart
book_woorm
I eventually found some of the reference code and the responces, thankyou, have pointed out a bit more. In my application its the temperature of the die that I'm after including the heating effects of sinking current on the digital pins!
When in use this particular 'box of magic' of a uno and ethernet shield inside will live in a pretty hot enviroment so I'm probably going to need to turn on a cooling fan or a peltier cell from time to time to stop it from getting cooked. Hence consistency is more important than absolute accuracy . I want to do this with out sacrificing any of the analog inputs to a separate temperature sensor. Trouble is those other inputs need an external Vref. I read that you cant turn on the internal reference voltage if an external one is connected. I suppose using an external reference 1.2V from a potential divider accross the 5V rail and ground will alter the maths a bit. Any body know if the internal reference is also just a potential divider?
Another of my projects, see separate post, has a tendancy to die unexpectedly. That is probably due to RF interferance but it could be  heat as well.
retrolefty
That is true. If you have any voltage wired to the Aref pin and have any of the internal reference voltages selected (Avcc and 1.1vdc for a Uno) then there will be a direct conduction path between that external Aref voltage and the internal voltage, never a good idea. A higher value series resistor on the Aref applied voltage can mitigate against possible damage perhaps per the second warning here: http://arduino.cc/en/Reference/AnalogReference
No, it's a fixed 'band-gap' voltage developed across an internal semiconductor, so it's accuracy is not effected by any variation of the applied Vcc or Avcc voltages.
Nantonos
Since you know which of your projects you are referring to, and we don't, taking a second to link to it would be a help to others reading the thread.
tuxduino
(OT): lefty, to quote-and-answer multiple times, just copy-n-paste the auto-added "quote" tag on top of the next paragraph, and add closing code tags by hand.
