Topic: Arduino won't upload (Read 30698 times) previous topic - next topic
RubinGrolsch
Oct 15, 2012, 05:19 pm Last Edit: Oct 15, 2012, 05:30 pm by RubinGrolsch Reason: 1
Hi there,
My Arduino UNO won't upload any sketches anymore, it has worked before, but now it just stopped working.
This is the error message it gives me:
avrdude: stk500_getsync(): not in sync: resp=0x00
This is the error message it gives when holding down shift:
avrdude: usbdev_open(): did not find any USB device "usb"
When uploading it the LED on pin 13 turns off, and the RX flashes 3 times. The TX stays off.
I'm using Windows 7 64bit, and I have also tried it on a Windows 7 32bit machine, with the same results.
I am also sure I have the right COM port selected, and that I have the correct board ticked under Extra --> Board
The sketch I last used with the Arduino was one for reading PPM signals, it was connected to my RC transmitter via port 1, and a ground port. It was sending back data to my computer, but suddenly it stopped.
If you need to know any more info on what I'm using or what I was doing, don't hesitate to ask.
Thanks in advance!
spcomputing
Have you tried CodingBadly's loopback test?
http://arduino.cc/forum/index.php/topic,73748.0.html
RubinGrolsch
I just tried it, and it failed the test. The RX LED flashes when I send something, but the TX doesn't, so I get nothing back.
(by serial monitor he did mean the thing that pops up when I press CTRL+SHIFT+M in the Programming environment, right?)
spcomputing
Quote
Yup, that is the one.  Okay, try this.  Download FLIP and install:
http://www.atmel.com/tools/FLIP.aspx
Leave the software closed after install and plug in the Uno and short the Reset and Gnd pins on the Atmega8u2/16u2:
This should cause a new device to be found in Windows.  Manually navigate the wizard to Program Files\ATMEL\FLIP 3.4.7\usb for the .INF file for your DFU.  After the installation is complete, open FLIP and then post back here which driver installed (Atmega16u2 or Atmega8u2).
RubinGrolsch
I have the R3 version of the Uno, so I am not sure where to connect the reset to the ground, because your pic is a bit different from my Arduino.
Will it also work if I just connect the reset on the bottom of the board (next to the pin where it says 3.3V), to a ground?
spcomputing
There should be a 3x2 header in that location next to the USB socket.
RubinGrolsch
Right, found it. But I'm having a bit of trouble with getting it to work, what do you mean by navigate the wizard? Tell it to look there for drivers? Nothing pops up when I plug the Arduino in, the only thing it does is make the sound it always makes when you attach a device.
spcomputing
When you have it plugged in and you short the pins, take a look at you Device Manager and see if it has a new device like Atmega16u2 or Atmega8u2.  If there is an unknown device, try to install the driver from Program Files\ATMEL\FLIP 3.4.7\usb folder.
RubinGrolsch
Sorry still no luck, it shows as an unknown device in device manager, and it can't find any drivers in the Program Files\ATMEL\FLIP 3.4.7\usb folder. Not even in the Program Files\ATMEL\FLIP 3.4.7 folder
spcomputing
Hmmm... I wonder why it is not taking the atmel_dfu_usb.inf file.  Have tried from the "Add Hardware" function?
spcomputing
Actually, I just thought of something.  See if the Arduino IDE Enhanced can help things out:
http://arduino.cc/forum/index.php/topic,118440.0.html
RubinGrolsch
Sorry, neither of those solutions work. It still isn't taking the .inf file, and although the enhanced suite doesn't give any errors, it still doesn't upload the file. Strange huh? What do you think the problem is?
spcomputing
I am afraid the Atmega8/16u2 got zapped.
Do you have a spare Arduino and (6) female to male jumpers or AVR programmer?
RubinGrolsch
I don't have a spare Arduino laying around, but I do have a jtag device. Will that do the job aswell?
spcomputing
If you can put it into a SPI programming mode.  Do you know which make/model you have?
