Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Programming an ATtiny85 with Arduino Code and Arduino Uno as Programmer  (Read 1692 times)
Offline Offline
Jr. Member
View Profile
Code:
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATtiny85
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [15]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x15
avrdude: Send: A [41] . [81]   [20]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: Send: A [41] . [82]   [20]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
avrdude: Send: A [41] . [98]   [20]
         Hardware Version: 1981277309
         Firmware Version: -2.-1937312626
avrdude: Send: A [41] . [84]   [20]
avrdude: Recv: . [02]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [87]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [89]   [20]
avrdude: Recv: . [00]
         Vtarget         : 429496729.4 V
         Varef           : 235765467.0 V
         Oscillator      : 194.021 kHz
         SCK period      : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x00
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done.  Thank you.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
avrdude and the ArduinoISP sketch lost synchronization.  It's an annoying bug in the ArduinoISP sketch.
Give this version a try...
http://arduino.cc/forum/index.php/topic,108797.msg824488.html#msg824488
Logged
Offline Offline
Jr. Member
View Profile
I downloaded this from your thread.
It worked with my single attiny (the core from MIT media lab worked with this one as well) but not with my onboard attiny.
Only the power led of the programmer lights up.
This is the error:
Code:
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Did you try the ArduinoISP sketch from the link I posted?
Logged
Wisconsin
Offline Offline
God Member
I LOVE THIS STUFF!!!!
View Profile
WWW
I tried that one codingBadly,
I keep on getting an error invalid conversion from 'const char*' to 'uint8_t'
Logged
Accelerate to 88 miles per hour.
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
Binary sketch size: 5,176 bytes (of a 32,256 byte maximum)
Compiles for me using Arduino 1.0.1 on Windows with Arduino Uno as the selected board.
Logged
Offline Offline
Jr. Member
View Profile
Im sorry I didnt find the attachment in the first place.
I tried the ArduinoISP sketch from the attachment.
However, I got the same results.
The two ArduinoISP sketches are identical, exept in line 126 heartbeat(); is commented off.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
I watched the board being programmed with the ATtiny soldered on it so Im quite sure its possible. It has eight holes for programming.
What device was being used to program the ATtiny? Maybe someone with greater knowledge of Atmel chips can say if you can still program these chips using ArduinoISP if the reset disable and/or the SPI program fuse is set, or do you have to use high voltage programming?
Logged
Offline Offline
Jr. Member
View Profile
I assembled the board on an exhibition myself and it was programmed by a self-made piece of hardware that was connected to a laptop.
I asked whether it is possible to program it my self with an arduino and I was told to use the tutorial from MIT Media Lab.
Logged
Leeds, UK
Offline Offline
God Member
Once the magic blue smoke is released, it won't go back in!
View Profile
WWW
if the reset pin is disabled and/or spi programming is disabled then you have to either use a hv programmer to program, or a hv programmer to set the fuse byte to enable both the reset pin and spi programming bits and then you can use isp to program again.
Logged
~Tom~
Offline Offline
Jr. Member
View Profile
Im not sure about the reset pin but they told me that it is possible to lock ATtinies and that this one is not locked.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
You need HVP if the reset pin has been configured as an I/O pin.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
You can "lock" it against SPI programming is by configuring the reset pin as a general I/O pin. I don't think there's any way to lock them against special programmers (HVP).
Logged
Leeds, UK
Offline Offline
God Member
View Profile
WWW
There is something else you can do if you want an extra IO pin, but still want to be able to program without a HVP, and that is to use a bootloader - the one I made for tiny85s and 84s is designed to allow serial programming (software uart) without the need for a reset pin.
Logged
~Tom~
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
If you want me to continue helping, post the verbose output.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
