Topic: At what voltage is a digital pin HIGH? (Read 4379 times) previous topic - next topic
holmes4
From the datasheet Section 28.2, for an UNO running at 5V a digital input will read high at a voltage of just 0.6V. Is this correct?.
Mark
Coding Badly
VCC = 2.4V - 5.5V
2. "Min." means the lowest value where the pin is guaranteed to be read as high
Is this correct?
Given the conditions, that's my interpretation.
retrolefty
#2
Oct 15, 2012, 09:14 pm Last Edit: Oct 15, 2012, 09:17 pm by retrolefty Reason: 1
Mark
No, the spec is saying that the minimum input pin voltage needed to be detected as a HIGH is .6 X Vcc (60% of the actual Vcc voltage being used). So for a 5 volt arduino board the minimum input pin voltage guaranteed to be detected as a HIGH is +3.0 vdc.
For a 3.3vdc powered board the value would be 1.98vdc.
Lefty
Ah, TC beat me to it.  ;)
holmes4
@retro and TC
now that makes a lot more sense!
Mark
Coding Badly
retrolefty
Yikes!  Sorry about that.
Well at least you cast your answer as an interpretation, not a fact.  :D
Lefty
