Loading...
Pages: [1] 2 3   Go Down
Author Topic: Is there Brown-out detection for Arduino Uno?  (Read 2509 times)
Nijmegen, Netherlands
Offline Offline
Newbie
View Profile
I have implemented a watchdog timer to restart my Arduino Uno when the code hangs. But I also want to avoid to run code when the voltage drops too much. Is there Brown-out Detection (BOD) for Arduino Uno? smiley-eek
I read http://arduino.cc/forum/index.php/topic,49044.0.html
And also found this fuse calculator http://www.engbedded.com/fusecalc.
But still I'm not sure how to set the BOD in a sketch.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
See page 48 of the datasheet. When enabled, the processor resets if the voltage drops below the brown-out level.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
It is much better to write proper code in the first place.
But yes a brownout detector is available. However you can only run this on an arduino powered by 5V as 3V3 is below the brownout threshold.
Logged
Grand Blanc, MI, USA
Offline Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
The brown-out detector can be set for 1.8, 2.7 or 4.3V via the extended fuse byte. Arduino Unos are set for the 2.7V level. I'm currently working on a project where it was beneficial to change it to 4.3V.
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Offline Offline
Newbie
View Profile
Yes I've read p48 of the datasheet and I'm using 5V through USB.
I found boards.txt in the IDE? It says:
Code:
uno.name=Arduino Uno
uno.upload.protocol=arduino
uno.upload.maximum_size=32256
uno.upload.speed=115200
uno.bootloader.low_fuses=0xff
uno.bootloader.high_fuses=0xde
uno.bootloader.extended_fuses=0x05
uno.bootloader.path=optiboot
uno.bootloader.file=optiboot_atmega328.hex
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.build.mcu=atmega328p
uno.build.f_cpu=16000000L
uno.build.core=arduino
uno.build.variant=stand
According to http://www.engbedded.com/fusecalc I should change the extended fuses from 0x05 to 0xFC to get 4.3V level.
Let's try that.... but now what? Is that it? Do I need to burn a bootloader?
« Last Edit: October 15, 2012, 04:02:57 pm by jrsikken » Logged
Offline Offline
Edison Member
View Profile
WWW
@jrsikken, either change the boards.txt file then burn the bootloader (which also burns the fuse bytes) or just change the one fuse byte with AVRDUDE.
BTW, the top five bits of the efuse sort of "aren't there", so setting the efuse to 0x04 turns out to be the same as 0xFC.
Logged
Offline Offline
Newbie
View Profile
@Jack, thanks for your reply! I will try tomorrow. Now it's bedtime!
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
That's one way, although you can change the fuses on their own. You need an ICSP programmer to do either. You can use another Uno for that.
Example:
http://www.gammon.com.au/forum/?id=11638
http://www.gammon.com.au/forum/?id=11635
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Isn't 2.7V a bit low? At 16 MHz the processor requires 3.78V. So it would become unreliable before the brown-out reset kicked in.
Logged
Offline Offline
Edison Member
View Profile
WWW
Agree completely, but it is what it is!
Logged
Offline Offline
Newbie
View Profile
Page 54 of the datasheet shows that I can read a brown-out reset flag. And also the watchdog reset flag. That's nice to monitor.
Logged
Offline Offline
Edison Member
View Profile
WWW
I hope someone else can confirm, but I think the bootloader may get in the way of that.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Better read this:
http://arduino.cc/forum/index.php?topic=64589.0
Logged
Offline Offline
Newbie
View Profile
Welcome back all, I tried changing the extended fuses from 0x05 to 0xFC in boards.txt to get 4.3V level, but it did not work. It showed error :  ***failed;  avrdude: verification error, first mismatch at byte 0x0000 0xfc != 0x04 avrdude: verification error; content mismatch. Then I tried to change extended fuses to 0x04, then it worked! Thanks to the comment of Jack Christensen : "BTW, the top five bits of the efuse sort of "aren't there", so setting the efuse to 0x04 turns out to be the same as 0xFC."
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
I don't know about the watchdog issue, but I just went through the brownout business a couple of days
ago. This info is VERY difficult to track down, no matter what anyone says, and the bits and pieces are
scattered all over the darn place. See Post #16 on the following thread,
http://arduino.cc/forum/index.php/topic,132124.msg995031.html
I have it as 2.7V, assuming I actually did find the correct source [jeesh], but this explains why I am able
to run my Duemilanove and UNO chips at both 5V and 3.3V.
« Last Edit: November 16, 2012, 02:16:58 pm by oric_dan(333) » Logged
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
Pages: [1] 2 3   Go Up
Print
Jump to:
