Loading...
Pages: [1]   Go Down
Author Topic: Cant afford a motor controller want to make my own fr 10$  (Read 1374 times)
Offline Offline
Newbie
View Profile
Hello once again,
I am making a RC robot..And you know I cant afford a sabertooth worth 59$..I want to make my own..I dont want many features but just want the DC MOTOR (link- https://c10645061.ssl.cf2.rackcdn.com/resources/dcdrivemotorspecs.pdf ) work like any normal servo.
I mean DC motor can't be connected to the receiver because of two reasons
1) It requires more current. mine requires 1amp according to the specs.
2) receiver gives out PWM or PPM? I think pwm..
So, I know sabertooth is perfect but I can't afford it.
What do I do? I an spend about 10$.
Actually I am building a stair climber robot/ combat robot like this-
Please help me urgently.
Thanks,
Rahul
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Add a geograhic location to your profile, better source help can then be provided.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
South Texas
Offline Offline
God Member
View Profile
IF you want to run 1 direction only you can use any transistor or MOSFET rated for more than 1 amp. But if you want to be able to reverse the motor you will need to make an H-Bridge and that will probably cost more than $10.
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
You might want to review that spec sheet again - that motor draws more than 4 amps when stalled; that is the number you want to pay attention to. So you need an h-bridge capable of supplying that, plus about 25% (so about 5 amps). For instance, this one would fit the bill, but is above (3x) your budget:
http://www.pololu.com/catalog/product/1373
You could try to find a different motor with a lower stall current. Another option (and not a great option) would be to use an L298 based motor driver, running in bridged mode, with a -really- big heatsink on it (and maybe active cooling). In bridged mode, the L298 can supply 4 amps; your motor stalled will go over that, of course, but the thermal protection on the L298 will kick in, -hopefully- protecting the L298. I am not sure how long it takes for it to kick in, but maybe if you are careful not to stall the motor too often (or too long), it may be able (for brief periods) to allow for a slightly higher current draw.
You can easily find L298 driver boards on Ebay for well under $10.00, drop shipped from China. Most are designed to provide separate motor channels, and some don't support "bridged mode" out of the box. You may have to review the circuit schematic for the board, and reference the spec sheet for the L298 (note - there are a couple versions of the L298 datasheet floating around out there - get both!) to determine how to hook up the bridged mode (you may need to mod the PCB). You'll probably also have to install a better heatsink than the one provided, too.
I also seem to recall in my ebay wanderings running across some fairly cheap ($15-20.00 USD) h-bridge boards based on a different chipset that would allow you to source quite a few more amps than the L298 - so you might do some more research there.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The TLE5206-2 is availaable on ebay for ~$9 shipped.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
Can it be controlled through RC signals which come through receiver?
Thanks !
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
If yout bot it is just going to be an RC bot, then you might want to considerr using continous rotation servos for the drive motors. Google and youtube search for terms like "RC robot" to see what others have done.
Logged
Offline Offline
Newbie
View Profile
I already have those motors(pitsco tetrix 1amp motor) which are good. I dont want to buy servos.
Other big combots have used big and costly motor controllers which i cant afford.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
For only $10 investment you might try some of the motor controllers on ebay. Some h-bridge chips have have dual h-bridges on them that might be paralled to control higher current. Good luck!
http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=arduino+motor+driver&rt=nc&LH_BIN=1
Logged
Los Angeles, CA, United States
Offline Offline
Full Member
View Profile
All Electronics sells this motor which has about the same dimensions and similar specs.
http://www.allelectronics.com/make-a-store/item/DCM-518/PRECISION-GEARHEAD-MOTOR-USED/1.html
Logged
C program run. C program crash. C programmer quit.
Pages: [1]   Go Up
Print
Jump to:
