Topic: Xbox wireless pad,processing and PWM (Read 1 time) previous topic - next topic
Max89
I have problem with processing script data output.
So there is https://dl.dropbox.com/u/35963789/processing%20code.txt processing  code - it send data from right trigger to first detected COM port.
And ardiono part [https://dl.dropbox.com/u/35963789/Arduino%20code.txt  - simple PWM sketch.
But there is some glitch - LED have only two states - on and off.  I'd probably messed input/output data types (HEX/DEC) and I can't find way out...
I have solution !
But it involves spherical chickens in frictionless vacuum...
PaulS
If the code is all that simple, post it here. If it isn't, create something simple that illustrates the problem, and post that here.
More likely, you are trying to use a pin that doesn't support PWM.
Max89
I have solution !
