Topic: Sparkfun RFID Starter Kit Problems (Read 3460 times) previous topic - next topic
05prentm
Hi guys,
I brought the Sparkfun RFID starter kit to play around with,
I managed to get my arduino to read the full ID into a string variable, however when i try and use that string to decided what to display on an LCD things go pear shaped.
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int SerInToArdu=7; //Defines pin data passes
    //to Arduino over from RFID reader
const int SerOutFrmArdu=3; //Not used, but
    //"fills" a parameter in the set up of
    //mySerialPort
String FullCode;
SoftwareSerial mySerialPort(SerInToArdu,SerOutFrmArdu);
//  Creates serial port for RFID reader to be attached to.
//  Using pins 0 and 1 is problematic, as they are also
//     connecting the development PC to the Arduino for
//     programming, and for the output sent to the serial
//     monitor.
Serial.begin(9600);//For access to serial monitor channel
Serial.println("Please Scan Card");
lcd.begin(16, 2);
lcd.print("Please Scan Card");
mySerialPort.begin(9600);
lcd.clear();
int incomingByte=0;//create and initialize a local variable
//The "then" part of the following will only execute
//  after the RFID reader has sent something to the Arduino
if (mySerialPort.available() > 0) {
             // read the incoming byte from the serial buffer
incomingByte = mySerialPort.read();
// show what was received
//Serial.print(incomingByte, DEC);
                //Serial.print(' ');
                FullCode = FullCode + " " + incomingByte;
                if (incomingByte==3){
                  Serial.println();
                  Serial.print("The Full Code is - ");
                  Serial.print(FullCode);
                  Serial.println();
                  if (FullCode == " 2 53 48 48 48 56 70 65 52 66 56 67 51 13 10 3")
                      lcd.print("Your Card Is");
                      lcd.setCursor(1,2);
                      lcd.print("67 51");
                      FullCode = "";
                  if(FullCode != " 2 53 48 48 48 56 70 65 52 66 56 67 51 13 10 3"); //" 2 53 49 48 48 55 66 69 65 52 50 56 50 13 10 3");
                      lcd.setCursor(1,2);
                      lcd.print("56 50");
                      FullCode = "";
                  delay(4000);
                  lcd.clear();
                  FullCode = "";
So instead of displaying that the card is "67 51" or "56 50" (last two numbers as the rest is checksum etc)
the display shows the correct text for card 56 50, but for 67 51 it shows
Your card is
56 50Your Card
Can anyone help?
GoingForGold
I'm not sure, could it be that you dont call setCursor(1,1) before you print "Your Card is"? Do the second time it just adds "Your Card is" to the end.
PaulS
If the full code is that ridiculous string, do something.
If the full code is not that ridiculous string, do something else.
Apparently, you've never encountered the else statement.
luxxtek
You check twice for "" 2 53 48 48 48 56 70 65 52 66 56 67 51 13 10 3" which does not make sense.
if that card is detected, you twice print to the display.
The second time you print to the display, it continues where the cursor is.
It does exactly what it is supposed to do.
Arduino leren ? ArdLab Gent - Lid van de STEM-Academie - www.ardlab.gent
PaulS
I thought that, too, at first. But, one uses == and the other uses !=. Still useless, but not the same.
GoingForGold
#5
Oct 16, 2012, 02:55 pm Last Edit: Oct 16, 2012, 02:59 pm by GoingForGold Reason: 1
Other idea, but I'm really not good in it: you declare the string as string, but can you use "string1=string2"? Wouldnt you have to use strcmp(string1,string2)?
Oh and that string also contains spaces (" "), which probably can't be contained by int (incomingByte). So whenever your incomingbyte should become a space, it doesnt. Or am I wrong?
PaulS
Where is string declared as a string?
FullCode is declared as a String, which is completely different beast. == works with Strings. strcmp() works with strings.
