Topic: Reading ascii in hexadecimal, need it in decimal. (Read 2394 times) previous topic - next topic
finthugo
Hi all,
I got a sensor that send me 16 bits in ascii values, the sensor send the values in ascii (between 500 and 64000). If the sensor is on middle range (32000) i get with the fuction Serial1.read() that same values in hexadecimal value of the ascii so i recive 51 50 48 48 48 (3 2 0 0 0).
I need that value (32000) to make math fuctions with that so i cant use a string to do that, so, anyone have any ideia what can i do?
the sensor is an inclinometer 0729-1752
thanks all
PaulS
You want to convert an ASCII string to an int. Seems like exactly what the atoi() function was invented for.
MarkT
finthugo
Thanks PaulS i will search for atoi() function :D
finthugo
it almost worked,
i first tried something like this :
char c;
      int i = 0;
      char buf[32];
      portOne.write('x');
      delay(200);
      do {
            c = portOne.read();
            if(c != -1)
                  buf[i] = c;
            i++;
            delay(10);
      } while ( c != -1);
      Serial.print("x = ");
      Serial.print((buf));
and that gave anwers like
ldadswdnajsndlka x = 32000
the number was correct and i like that, but the just needed to put off the "iuhuiasdansdn",
then i tried with the atoi fuction just changing the last line for  Serial.print(atoi(buf));
it that gave me:
x = 32000
x = -32000
its working for -500 to -32000 then it goes to 32000 and get lowering to 500 for the other side of the inclinometer.
That wasnt bad but what i need is 500 to 64000 (and thats what sensor send i tested it on realterm).
Any idea what it could be ?
thanks
PaulS
      do {
            c = portOne.read();
            if(c != -1)
                  buf[i] = c;
            i++;
            delay(10);
      } while ( c != -1);
buf is not a string. You should not be passing it to functions, like atoi() or Serial.print() that expect strings.
A string is a NULL terminated array of chars. buf IS an array of chars, but it is NOT NULL terminated, therefore it is NOT a string.
You need to fix that.
You should also learn about Serial.available().
You should also learn about sending end-of-record markers, and reading properly delimited records. Then, you would need that stupid delay() in the loop.
The atoi() function converts a string (which you don't have) to an int (a signed int). The strtoul() function deals with unsigned longs. That might be more useful.
finthugo
it does not compile with  strtoul()
it says invalid conversio from 'char' to 'const char'.
AWOL
We can't see the "it" that does not compile.
finthugo
sorry,
i mean it meaning by the code.
i tried the  strtoul() fuction with the "c", and with the "buf" for both it does not compile.
AWOL
PaulS
Then use a cast!
guix
#11
Oct 16, 2012, 05:54 pm Last Edit: Oct 16, 2012, 06:03 pm by guix Reason: 1
Edit: sorry it was useless for what you want to do.. :)
