Topic: help with wifi-proto (Read 4169 times) previous topic - next topic
xangomango
hi i have a question about how connect this wi-fi (http://www.mikroe.com/downloads/get/1051/wifi_p_manual_v100.pdf) to an arduino one. Thank you :)
PaulS
i have a question about how connect this wi-fi...to an arduino one.
Are you going to ask it?
xangomango
Yes i'm asking if anybody can explain me how connect this device to an arduino one. Sorry for my english, thank you
pylon
The module seems to use the same chip as the WiShield 2.0 from Asynclabs, so you probably can use their library (https://github.com/asynclabs/WiShield). Take a look at their wiki page about the shield to get an idea how to connect it: http://asynclabs.com/wiki/index.php?title=WiShield_2.0
xangomango
xangomango
Sorry but i'm new in that and i don't understand how to connect it. Somebody has more information?
pylon
GND to GND, Vcc probably to 3V3 (but this doesn't get clear from the "User Manual" sheet), MISO to pin 12, MOSI to pin 11, SCK to pin 13, INT to pin 2, CS to pin 10, RST to Reset, CE to GND. This is my best guess because your linked sheet does not include much information.
xangomango
this days i have try that this works and i couldn't achieve. In this moment i'm connecting this ports:
CE -> GND
RST -> RESET
CS -> 10
INT -> 8
SCK -> 13
MOSI -> 11
MISO -> 10
BOTH VCC TO 3.3V
GND -> GND
And it doesn't work.
Anyone can help?
Thank you!
pylon
CS -> 10
MISO -> 10
This cannot work.
And you may destroy your module, I don't know if it's capable of receiving 5V on it's comm pins. You may have to install level converters.
INT -> 8
The default is pin 2, have you changed the library accordingly?
xangomango
sorry, i mean MISO -> 12. And yes, i changed the library.
I do the steps explain in this site: http://theiopage.blogspot.com.es/2011/10/connecting-mrf24wb0ma-to-arduino.html
And when i do the example that doesn't work.
Thanks you!
pylon
You understand that this information is of almost no value to us. What doesn't work? What output do you get? What are you doing to get that output? Describe the network environment you're trying it. Post the code your trying with.
Just to check: post the change you made.
xangomango
in this web : http://theiopage.blogspot.com.es/2011/10/connecting-mrf24wb0ma-to-arduino.html
the example shows that when you open google xhrome and put the 192.168.1.2 in the navigator, arduino sens you a web. In my case this web doesn't show.
the code is the next:
#ifdef USE_DIG8_INTR
   // set digital pin 8 on Arduino
   // as ZG interrupt pin
   PCICR |= (1<<PCIE0);
   PCMSK0 |= (1<<PCINT0);
#endif
pylon
#endif
This is the relevant code but not the code that you should have changed. This is probably the reason it doesn't work for you.
xangomango
#13
Nov 13, 2012, 05:01 pm Last Edit: Nov 13, 2012, 05:20 pm by xangomango Reason: 1
yes i have the same code and the connections that i said in the last post and it doesn't work :S.
EDIT: an image with hardware connections http://imageshack.us/f/855/20121113170322.jpg/.
Thank you
pylon
If this is true, you haven't done the necessary change and it's obvious that it doesn't work.
You have to change in the file spi.h:
// Uncomment one line below to
// specify which Arduino pin
// to use as WiShield interrupt
#define USE_DIG0_INTR // use digital pin 0
//#define USE_DIG8_INTR // use digital pin 8
to
//#define USE_DIG0_INTR // use digital pin 0
What kind of WiFi access point do you have? I made the experience that it doesn't work with every kind of access point, although with most APs I tested it worked (I have one type that doesn't work).
