Topic: Aquarium Auto Top Off Fail safe (Read 7526 times) previous topic - next topic
racer_X_123
const int ledPin = 2;
const int floatSwitch = 4;
int floatStatecounter = 0;
int buttonState = 0;
long lastButtonState = 0;
long failSafe = 5000;
  pinMode(ledPin, OUTPUT);
  pinMode(floatSwitch, INPUT);
  //get switch state
  buttonState = digitalRead(floatSwitch);
  if (floatSwitch == HIGH){
    floatStatecounter = millis();
if (millis() >= 5000){
  digitalWrite(ledPin, HIGH);
Serial.println(buttonState);
delay(10);
Ok, Im getting the LED to light right when the switch falls to HIGH.
I think it has to do with this right here
Arrch
Rarely does this code actually do what the programmer intended. millis() returns the number of milliseconds since the Arduino was last reset or powered on, so that if statement is checking to see if it's been 5 seconds since power on/reset. Another thing to think about is that you are setting floatStatecounter, but never using it again. These two issues are related.
racer_X_123
Ok, I will work on this tomorrow and see what I can do with it. I  feel like I almost have it or else I am completely lost...
I don't want to give in and just ask for the code just yet so bear with me!
Thanks for your help!
racer_X_123
Ok, so I am like 95% done now and the code is partially working right.  The problem I am having is resetting the counter when the switch is dropped back to the LOW state.  As of now the code simply just stops counting.  I though that if I reset the floatStatecounter = 0 it would reset on the way back around through the loop.
Any help?
  //Set Float State Counter = 0
  floatStatecounter == 0;
  //get switch state
  if (buttonState == HIGH){
    floatStatecounter++;
if (floatStatecounter >= 5){
Serial.println("buttonState:");
Serial.println("floatStatecounter");
Serial.println(floatStatecounter);
invader7
#19
Oct 19, 2012, 02:19 am Last Edit: Oct 19, 2012, 02:27 am by invader7 Reason: 1
typography or ...??  floatStatecounter == 0; it should be  floatStatecounter = 0;
also you can try remove this line and do it like this
if (buttonState == HIGH) { floatStatecounter++; } else { floatStatecounter = 0; }
racer_X_123
Ok, thanks, I fixed it and added a second output to control a pump relay.
const int pump = 5;
  pinMode(pump, OUTPUT);
  //get switch state
    digitalWrite(pump, HIGH);
  else{
  digitalWrite(pump,LOW);
else{
  digitalWrite(ledPin, LOW);
Serial.println("pump State");
Serial.println(pump);
I used delay() at the end of the code to slow it down, What if I wanted to add, say, Temperature monitoring later on to this code so I can control fans?  Would this delay(1000) effect that?  Basically what I am asking is will using this delay(1000) negatively effect future sampling code?
Arrch
It may. If you want to do any time critical actions, then you'll run into issues down the road.
marcello.romani
The answer is in Blink without delay example.
jerseyguy1996
#23
Oct 19, 2012, 03:07 pm Last Edit: Oct 19, 2012, 03:13 pm by jerseyguy1996 Reason: 1
Why not just incorporate some mechanical redundancy into your design.....i.e. a 2nd float switch mounted at the very top of the tank that will trigger the arduino to shut off the pump if it switches states?  That is what I did with mine.  Actually mine has 3 float switches.  One mounted at the top as an emergency cutoff, one mounted at the high end of my desired water level and one mounted at the low end of my desired water level.  I call them:
High_Float Switch
Low_Float_Switch
Emergency_Cutoff_Switch
Pseudo-code is:
If High_Float_Switch is off && Low_Float_Switch is off && the pump is off  //water level is too low
turn on the pump
If High_Float_Switch is on && Low_Float_Switch is on && the pump is on//water level is correct
turn off the pump
If Emergency_Cutoff_Switch is on && the pump is on //water level is too high
turn off the pump
The reason for having a high and low float switch is to avoid the rapid cycling of the pump that can occur as the float switch bobbles up and down on the surface of the water.  If you don't choose to do it that way, I would suggest putting in a time delay that will cause the pump to run a minimum amount of time after it receives a triggering pulse from the float switch.  Just make sure that you don't use the delay() function for this because delay() will cause it to miss a triggering pulse from the Emergency_Cutoff_Switch unless you put that routine into an interrupt which probably wouldn't be the best solution.
Arduino Uno;
Mega328
wildbill
Another precaution I've seen suggested in acquarium threads is to restrict how often the system can respond to the low water level indicator. You might for example, only allow the top-up pump to run once a day, thus resticting the possibility of a serious flood if you have hardware issues.
marcello.romani
I'd make the emergency float switch physically interrupt the pump power, so the pump will be shut off even if the Arduino or the sketch is non-functioning.
Having an emergency switch pass through software is scary ;-)
jerseyguy1996
Really good point and something that I should probably implement with my setup.  I was thinking more about the possibility of a malfuntioning float switch (i.e. a snail deciding to crawl on it and holding it in the down position) without even considering a software problem.  Just make sure that you don't run the pump current through the float switch.  Pick up a 5v solenoid and use the float switch to trigger the solenoid on and off.  Run the pump current through the solenoid.
Arduino Uno;
Mega328
racer_X_123
Wow, thanks for all the advise.  I also want to thank everyone for their help!  I am appreciative that you guys didn't just code this for me.  It felt so good figuring it out on my own and now I have a much better understanding of how the code syntax needs to be written.
Thanks again, and im almost wishing I had bought the mega board instead of the uno...after I add the LCD display I won't have many pins left...
marcello.romani
You can always use a serial LCD display. They've got a PIC or AVR uC on the back that takes care of driving the LCD pins. You just send chars to it via a serial interface and they're displayed.
I've bought three or four different types. They just need one pin (plust vcc and gnd, of course), because they're receive-only.
