Topic: Sometimes Atmega does not wake up (Read 975 times) previous topic - next topic
ale8484
Hallo
I have an Atmega328, with 16MHz crystal oscillator, 5V stable supply. I want Atmega wakes up when something happens (one of the two sleep pins goes low), but the problem is: after about 1 hour of normal running, Atmega does not wake up anymore. 5V supply is ok, oscillator too.. but no wake up. If I reset it, everything goes well. This is the code:
#include <avr/sleep.h>
#include <avr/power.h>
#include <XBee.h>
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
ZBRxResponse rx = ZBRxResponse();
ModemStatusResponse msr = ModemStatusResponse();
uint8_t payload[] = {
  0, 0 };
// SH + SL Address of receiving XBee
XBeeAddress64 addr64 = XBeeAddress64(0x00000000, 0x0000FFFF);
ZBTxRequest zbTx = ZBTxRequest(addr64, payload, sizeof(payload));
ZBTxStatusResponse txStatus = ZBTxStatusResponse();
int pin2 = 2; //Interrupt Pin from Motion Detector
int pin3 = 3; //Interrupt Pin from UART (Antenna)
int pin4 = 4; //ON-OFF Pin for 3.3V
int pin8 = 8; //ON-OFF Pin for Motion Detector
int pin9 = 9; //ON-OFF LEDS
int batterypin = A0;
int batteryvoltage=0;
int tmax=0;
int ledpin=13;
boolean flag=0;
boolean mdstatus=0;
String stat="IDLE";
unsigned long timer=0;
unsigned long alarmstart=0;
*  Name:        pin2Interrupt
*  Returns:     Nothing.
*  Parameters:  None.
*  Description: Service routine for pin2 interrupt
void pin2Interrupt(void)
  /* This will bring us back from sleep. */
  /* We detach the interrupt to stop it from
   * continuously firing while the interrupt pin
   * is low.
  detachInterrupt(0);
  detachInterrupt(1);
*  Name:        enterSleep
*  Returns:     Nothing.
*  Parameters:  None.
*  Description: Enters the arduino into sleep mode.
void enterSleep(void)
  /* Setup pin2 as an interrupt and attach handler. */
  attachInterrupt(0, pin2Interrupt, LOW);
  attachInterrupt(1, pin2Interrupt, LOW);
  delay(100);
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  sleep_mode();
  /* The program will continue from here. */
  /* First thing to do is disable sleep. */
  sleep_disable();
*  Name:        setup
*  Returns:     Nothing.
*  Parameters:  None.
*  Description: Setup for the Arduino.
  //  Serial.begin(9600);
  xbee.begin(9600);
  /* Setup the pin direction. */
  pinMode(pin2, INPUT);
  digitalWrite(pin2, HIGH);
  pinMode(pin3, INPUT);
  digitalWrite(pin3, HIGH);
  pinMode(pin4, OUTPUT);
  digitalWrite(pin4, LOW);
  pinMode(ledpin, OUTPUT);
  digitalWrite(ledpin, LOW);
  pinMode(pin9, OUTPUT);
  digitalWrite(pin9, HIGH); //Schmitt Trigger will set to LOW
  payload[0] = 0;
  payload[1] = 1;
  Serial.println("Initialisation complete.");
*  Name:        loop
*  Returns:     Nothing.
*  Parameters:  None.
*  Description: Main application loop.
int seconds=0;
  //check Motion Detector Status
  mdstatus=digitalRead(pin2);
  //check Battery status
  batteryvoltage=analogRead(batterypin);
  //  Serial.println(stat);
  if((batteryvoltage>=0))
    if(stat=="OK")
      flag=0;
      stat="OK";
      flag=1;
  if((batteryvoltage<0))
    stat="LV";
    // Turn Off Antenna and Led
    digitalWrite(pin4, HIGH);
    // Turn Off Sensor
    digitalWrite(pin8, LOW);
    delay(60000);
    flag=1;
  if(stat=="OK")
    if(flag)
      // Turn on antenna and sensor
      //     Serial.println("Turn on Antenna and Sensor");
      //     Serial.println("Wait for Sensor Init...");
      // Turn ON Antenna and Led
      // Turn ON Sensor
      digitalWrite(pin8, HIGH);
      // Wait Initialization
      // delay(120000);
    //    Serial.println("Check if alarm from sensor");
    if(!mdstatus)
      xbee.send(zbTx);
      //      Serial.println("Send RF Data");
    //    Serial.println("Reset and Start Timer");
    timer=millis();
    alarmstart=millis();
    do
      tmax=15000;
      digitalWrite(pin9, HIGH); //if there is Schmitt Trigger will set HIGH and turn on LED
      digitalWrite(ledpin, HIGH); //Cancellare
      //  Serial.println("Check New Alarm from Motion Detector");
      //  Serial.println((millis()-timer),DEC);
      if(!mdstatus)
        if((millis()-alarmstart)>5000)
          timer=millis();
          xbee.send(zbTx);
        xbee.readPacket();
        if (xbee.getResponse().isAvailable())
          timer=millis();
        //     Serial.println("Check UART alarm");
      // statement block
    while ((millis()-timer)<tmax);
    // Serial.println("Enter Sleep mode...");
      digitalWrite(pin9, LOW); //if there is Schmitt Trigger will set HIGH and turn on LED
      digitalWrite(ledpin, LOW); //Cancellare
    enterSleep();
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
