Topic: ATtiny 85 to trigger Canon camera using IR LEDs and laser tripwire (Read 7242 times) previous topic - next topic
Manticorp
Hey everyone,
I'm using Arduino and ATtiny to trigger my camera using IR LEDs. I'm using the great library found here:
http://sebastian.setz.name/arduino/my-libraries/multi-camera-ir-control/
I managed to set up my Arduino fine as a trigger - whenever I trip the laser the camera triggers almost instantly (I think there's probably about a 1-5ms delay) and I even hooked up a mode switch (trip forever or trip once).
Here's the basic circuit (sorry for the basic schematic - just whipped up on a whiteboard):
However, when I try the code on the ATtiny, suddenly the camera no longer fires. I've tried plugging a normal LED where the IR LED is and I can see that it's firing - it's just not triggering the camera for some reason.
I've tried using 3.3V input and 5V input for the ATTiny and the IR LED but no dice.
Here's the device wired up:
My guess is the timing on the ATTiny isn't precise enough to trigger properly - but I have no way of testing this.
Does anyone have any suggestions?
I'd also appreciate any feedback - this is about the third circuit I've ever built (blink!) so any general advice would be great :) I'd really like to get this is a standalone item.
The good part is, it works fine with the Arduino!
johnwasser
Your schematic shows a transistor grounding the cathode of a diode connected directly to Vcc.  Is that the yellow LED?  Shouldn't there be a current limiting resistor somewhere in there?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
MichaelMeissner
If I recall the IR protocol, it flashes the IR light for precise periods.  It might be the library you are using is tuned towards 16Mhz, and perhaps you are running the ATtiny85 at a different speed like 8Mhz or 20Mhz.
Manticorp
Ah yes of course, I am running the ATtiny at 8Mhz! The code for the library shows this to fire the Canon camera:
Code: [Select]
void Canon::shutterNow()
for(int i=0; i<16; i++) {
    digitalWrite(_pin, HIGH);
    delayMicroseconds(11);
    digitalWrite(_pin, LOW);
  delayMicroseconds(7330);
Does the delayMicroseconds() function depend on the speed that chip is running at then I assume? Would I be safe enough in just halving all the times to get the same effect without having to use a crystal do you reckon?
It is a yellow LED that I just used to visually test if the rest of the circuit was working, but you're right I should have had a resistor in there really! My bad.
Thanks for your help!
Erni
Maybe it is a timing issue due to the attiny using internal oscillator. The Arduino use a crystal .
You can tune the internal oscillator (I just don't know how, but Coding Badly has a TinyTuner)
Manticorp
Thanks, I'll give it a look  :)
Coding Badly
I now have two of them.  :D  (disregarding all the test, experimental, and prototype ones)
You should put a pull-up resistor on the RESET pin.
Manticorp
Thanks, that's a good point, I completely forgot about the reset pin! I've just been looking at your Tiny Tuner stuff here:
http://arduino.cc/forum/index.php/topic,8553.0.html
and I just want to get a few things straight before I potentially damage a chip...
I upload the sketch 'Interactive_to_Serial' to the ATTiny.
I connect PB3 (which is transmitting) to the serial receiver and PB4 (which is receiving) to the serial transmitter.
The Receive/Transmitter presumably can just be the TX/RX pins on an Arduino Uno for example?
Then, set up the Uno to transmit 'x' at baud rate 9600 over TX and reset the ATTiny85.
Forgive me if anything here seems wrong, I'm new to this whole thing  :smiley-roll-sweat:
Manticorp
Okay some updates:
I Found a good post on a blog from a guy who made his own camera remote:
http://www.doc-diy.net/photo/eos_ir_remote/index.php
and I managed to get his code up and running on the ATtiny85 AND it triggers the camera! SO I now know it's possible...
I was able to create a small loop that just fired the camera every second:
Code: [Select]
#define F_CPU 7900000 // clock frequency, set according to clock used!
#include <inttypes.h>
#include <stdlib.h>
#include <avr/io.h>
#include <avr/sleep.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#define HPERIOD 0.01524  //delay between pulses
#define RATIO 0.4       // --?
#define NPULSES 16 //number of pulses
#define LEDOFF 0b00000001
#define LEDON  0b00000010
int main(void)
  uint8_t i;
  DDRB  = 0b00000010; // pin PB0 is input, pins PB1-PB4 are output
  PORTB = 0b00000001; // pull-up for input pin PB0
  while(1){
    for(i=0;i<NPULSES;i++)
      PORTB = LEDON;
      _delay_ms(HPERIOD);
      PORTB = LEDOFF;
      _delay_ms(HPERIOD);
    _delay_ms(7.33); // instant
      PORTB = LEDON;
      _delay_ms(HPERIOD);
      PORTB = LEDOFF;
      _delay_ms(HPERIOD);
    _delay_ms(1000);
The same person goes into detail about the timing and tolerances here:
http://www.doc-diy.net/photo/rc-1_hacked/
However, when I replace the PORTB = LEDON/LEDOFF; parts of the code above with standard arduino code (digitalWrite(pin,HIGH)) it ceases to work properly...
I'm tearing my hair out over here!
johnwasser
Note that writing a value to PORTB will change ALL pins associated with PORTB.  It looks like LEDON and LEDOFF are changing two different pins.  One of those pins is an input so writing to it is turning the pull-up resistor ON (1) and OFF (0).
Manticorp
Ah thanks, I'm still getting the hang of all this programming microchips stuff (obviously!). I'm so used to web programming and whatnot, all this 'hardware' stuff is really confusing ('what the hell is a register!?').
I'm beginning to think that instead of relying on programming for all of this (the mode switching, LDR calibration, etc) I should be taking a more hardware approach and designing the circuit a bit better and just using the little ATtiny85 to send the pulses that trigger the camera, that way I can keep the ATtiny in sleep mode most of the time and only turn it on when I need a pulse sent. Hmm.
Coding Badly
Just include 220 ? (or higher) resistors in series: Arduino ? resistor ? ATtiny85.  You can never go wrong with a series resistor.   ;)
Quote
I believe that is correct.
Quote
Yes but you will have to remove the 328 processor from the circuit.  You can either force it into reset by connecting a jumper from RESET to GND or you can remove the 328 processor from the board (with the power off).
Manticorp
AHA! Thank you good sir! I could NOT work out why it wasn't working, fantastic! Thank you so much!
Erni
OK
Now i think I have got it too ?
I get this result (Attiny85 @8mHz)
Code: [Select]
AA    BigSteps   This         -1  41150  -11273  57  13807  -31442     42  33749  -782  185  62765  31835     45  1522  110  155  64399  -3397
 2     AB    BigSteps   This         42  1496   20  57  13807  -31442     43  33749  -782  185  62765  31835     45  1522  110  155  64399  -3397
 3     AA    Confirm    This         41  1496   20  0      0  -31442     42  1496   20  1   1496  31835     43  1508   40  1   1508  -3397
 4     AA    Confirm    This         41  1496   20  0      0  -31442     42  1498   20  2   2994  31835     43  1508   40  1   1508  -3397
 5     A9    Confirm    Left         41  1496   20  0      0  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
 6     A9    Confirm    Left         41  1490   20  1   1490  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
 7     A9    Confirm    Left         41  1488   20  2   2978  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
 8     A9    Confirm    Left         41  1491   20  0      0  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
 9     A9    Confirm    Left         41  1491   20  1   1491  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
10     A9    Confirm    Left         41  1491   20  2   2982  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
11     AB    Confirm    Right        41  1489   20  3   4471  -31442     42  1497   20  3   4491  31835     43  1508   40  1   1508  -3397
12     AB    Confirm    Right        41  1489   20  3   4471  -31442     42  1497   20  3   4491  31835     43  1508   40  2   3016  -3397
13     AA    Finished   This         41  1489   48  3   4471   7452     42  1497   15  3   4491   7485     43  1508   40  3   4524   7540
Copy-and-paste the following line of code at the top of setup...
 OSCCAL = 0xAA;
                                    Left                               This                               Right
Step  OSCCAL  State      Position    Cal   9bt  Err  #   C9bt   CClk    Cal   9bt  Err  #   C9bt   CClk    Cal   9bt  Err  #   C9bt   CClk
 1
That means that
1. in my sketch i will do like this
Code: [Select]
OSCCAL = 0xAA;
2. or I could store the value in EEPROM , and read it from there in setup()
Coding Badly
...the error at that tuning is approximately (1497 - 1500) / 1500 = -0.20%
