Topic: Connector suggestion - Simple question (Read 920 times) previous topic - next topic
Marvinfly
At the moment I have three cables sticking out of the header pins on the top of my arduino. These control a relay. Two side by side, one on it's own.
They are not very secure, movement can sometimes pull them loose.
What type of connector do I need to attach these to the arduino to stop them coming loose?
I'm guessing a male header pin but I can't find anything that looks right anywhere.
dannable
I would use some male 'dupont' style connectors, but for best results you need a crimping tool.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
fungus
Is it for a permanent installation? Remove the header strips from the Arduino and solder directly to the board.
For development there's all sorts of shields which give you screw terminals for the pins, etc., eg. http://www.ladyada.net/make/protoscrewshield/
Or you can just use thicker wire or wire with proper pins on the end.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Marvinfly
okay thanks. I can't take the header pins off.. it's on an LCD shield suspended by the header pins above an Ethernet shield.. It'd go all wonky if I did that.
I've got a crimping tool, that's no problem. The place where I normally get my parts in the UK doesn't seem to stock the right type of crimp pin though. Maplin seems useless as well. Any ideas where I can pick some up?
