Loading...
Pages: [1] 2 3   Go Down
Author Topic: E l'atmega 8L dove lo mettiamo?!?!?  (Read 914 times)
Dueville (VI)
Offline Offline
Edison Member
http://cesarecacitti.wordpress.com/
View Profile
WWW
In questi giorni mi sono procurato degli atmega8L alla modica cifra di un dollaro l'uno  smiley-money, ma la straodinaria guida di Menny non gli programma, qualcuno sa darmi qualche dritta? smiley-mr-green
Logged
Arduino UNO r3, Arduino MEGA 1280, adafruit motor shield, bluetooth module, enc28j60 shield.
Ultimi acquisti: un sacco di componenti elettronici, ATTEN AT 8586
Forum Moderator
Italy
Offline Offline
Brattain Member
Don't know what I do
View Profile
non sono al 100% compatibili con la famiglia Atmega88/168/328, e va creata una board apposita nel file boards.txt ed altre cose. ma trovi tutto in alcuni post di vecchie discussioni, sono già stati trattati in passato
Logged
Dueville (VI)
Offline Offline
Edison Member
View Profile
WWW
ho cercato ma non sono riuscito a trovare documenti
Logged
Monselice PD Italy
Offline Offline
Faraday Member
фон Крыса
View Profile
Qui hai guardato ?
http://www.hackmeister.dk/2011/01/new-bootloader-file-for-atmega8l/
http://electronics.stackexchange.com/questions/23454/is-atmega8l-8pu-compatible-with-atmega-328-on-arduino-uno
http://www.arduino.cc/playground/Learning/Atmega83-3V
Logged
Se corri veloce come un fulmine, ti schianterai come un tuono.
Dueville (VI)
Offline Offline
Edison Member
View Profile
WWW
non mi funziona smiley-sad
mi fornisce una marea di errori smiley-sad
Code:
Blink.cpp:10:21: error: Arduino.h: No such file or directory
Blink.cpp: In function 'void setup()':
Blink:14: error: 'OUTPUT' was not declared in this scope
Blink:14: error: 'pinMode' was not declared in this scope
Blink.cpp: In function 'void loop()':
Blink:19: error: 'HIGH' was not declared in this scope
Blink:19: error: 'digitalWrite' was not declared in this scope
Blink:20: error: 'delay' was not declared in this scope
Blink:21: error: 'LOW' was not declared in this scope
Logged
Monselice PD Italy
Offline Offline
Faraday Member
фон Крыса
View Profile
Quale hai usato ?
Con che IDE ?
Prova ad aggiungere la Arduino.h magari poi ti va  smiley-sweat
Logged
Dueville (VI)
Offline Offline
Edison Member
View Profile
WWW
Quale hai usato ?
Con che IDE ?
Ho usato questo: http://www.hackmeister.dk/2011/01/new-bootloader-file-for-atmega8l/
Sia sotto 1.0.1 che sotto 0022
Logged
Rome (Italy)
Offline Offline
Tesla Member
"Il Vero Programmatore ha imparato il C sul K&R, qualunque altro testo è inutile e deviante."
View Profile
WWW
Non è solo una questione di bootloader, ti serve anche il core per l'ATmega8L, senza quello è normale che non riesci a compilare, operazione questa che è indipendente dal bootloader.
Logged
Dueville (VI)
Offline Offline
Edison Member
View Profile
WWW
li c'era il file da mettere su boards.txt, dove trovo il core?
Logged
Lamezia Terme
Offline Offline
Shannon Member
Le domande di chi vuol imparare rappresentano la sua sete di sapere
View Profile
WWW
Premetto che ho lavorato con la versione ATmega8 e non 8L, mi pare che quest'ultima operi a frequenze inferiori, quindi attenzione a come lo stai configurando in hardware. Nelle board dell'IDE ce n'è almeno una che usa l'ATmega8, inizia a provare con quella, visto che lì c'è sia il core che il bootloader disponibile.
Cecé, male che vada li programmiamo via AVRDUDE, ma prima prova con ciò che ti ho detto.
Logged
Guida alla programmazione ISP e seriale dei micro ATMEL (Caricare bootloader e sketch):
http://www.michelemenniti.it/Arduino_burn_bootloader.php
Guida alla Programmazione ATmega328 noP:
http://www.michelemenniti.it/atmega328nop.html
Articoli su Elettronica In:
http://www.michelemenniti.it/elettronica_in.html
Forum Moderator
Italy
Offline Offline
Brattain Member
View Profile
Tra le "altre cose" c'era appunto la necessità di trovare un core, cioè un insieme di librerie pronte per poter accedere alle periferiche del micro. E poi non è detto che, fatto tutto questo, tra le "altre cose" non ti servano anche versioni modificate delle librerie che usi perché spesso esse sono spesso scritte solo per supportare UNO e MEGA, ossia Atmega328 e Atmega2560.
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
Posso garantire che l'ATmega8 non ha alcun problema a funzionare con la normale "dotazione" dell'IDE, lo può confermare BUD Pelletta col quale facemmo i primi test di programmazione ISP, sia con l'8 che con il 168, e non abbiamo mai avuto problemi; personalmente ho fatto solo test di programmazione, ma lui so che l'ha usato per fare diversi lavori. La certezza è data dal fatto che esistono versioni "Arduino" (NG or older) che hanno usato come micro proprio l'8, e sono ancora supportate dall'IDE, visto che sono presenti come board ufficiali, quindi pernso ci sia anche un bootloader funzionante.
Logged
Deep south of Italy
Offline Offline
Faraday Member
The quieter you become, the more you can hear
View Profile
confermo quanto detto da menniti.
se non ricordo male sull'ultimo atmega8 che avevo ,ci avevo caricato l'optiboot ed andava a meraviglia.
Logged
Dueville (VI)
Offline Offline
Edison Member
View Profile
WWW
Io ti dico che con i miei Atmega8 va tutto a meraviglia, mentre con gli 8L no, ho contattato il venditore (mi hanno mandato due Atmega8 e tre Atmega8L, vedo di farmi spedire tre atmega8).
Per quanto riguarda gli 8L ho proprio voglia di fare esperimenti, ma non so quanto siano fattibili sotto Mac (avrei il pc Winzoz ma è una rottura usarlo  smiley-mr-green)
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
sì, ma continui a non dire niente di come li stai usando, vediamo se passa la Astrobox (TM) smiley-twist
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
