Hello everybody !
Just beggining with arduino and I have some issue with a parallax sonic ultrasonic.
Error is :
error: a function-definition is not allowed here before '{' token .
The line which cause this is (I think)
long microsecondsToInches(long microseconds)
The entire code is
// this constant won't change. It's the pin number
// of the sensor's output:
const int pingPin = 7;
const int pompe=12;//Pour controler la pompe
// initialize serial communication:
pinMode(pompe,OUTPUT);
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
while(cm <= 5){ // Tant que la distance entre le parallax et ce qu'il détecte (c'est à dire l'eau) est de moins de 5 cm alors...
digitalWrite(pompe,HIGH); // On active la pompe
if (cm >= 15) { // Si la distance entre le parallax ce qu'il détecte (c'est à dire l'eau) est de plus de 15 cm alors...
digitalWrite(pompe, LOW); // On éteint la pompe
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
Thanks a lot !!
Merci Beaucoup !
