Topic: Rotary Switch Colour Selector help needed (Read 2438 times) previous topic - next topic
pekkaa
#15
Oct 23, 2012, 09:15 pm Last Edit: Oct 23, 2012, 09:35 pm by pekkaa Reason: 1
I don't think a rotary switch is as easy as you think... it would need quite a lot of code and I bet there's no library for it.
A rotary encoder library with examples is probably easier for a novice to get working.
I don't think a rotary switch is as complicated as you think  ;) I already provided guidelines for the sketch in reply #1. If the OP has any programming experience at all, he will probably write the code in the time it would take to find a suitable library for a rotary encoder.
(edit: typo)
pekkaa
Well from a programming stand point, I think a seven level deep block of nested if-then-else statements evaluating if each pin is TRUE would be fairly simple.  However, it would take up quite a few lines by itself and be somewhat cumbersome if you ever had to debug it. ;)  Furthermore it's perhaps the most compact ways to express the logic without getting into rather arcane tricks.
Why on earth would it need to be anything that complicated? A simple loop through the pins is enough, assuming he uses subsequent (is this the right word?) pins.
Code: [Select]
byte colorNum = 0;
for (byte pin=2; pin <= 8; pin++) {
    if (digitalRead(pin) == LOW) {
      colorNum = pin;
if (colorNum) color = colorMap[colorNum];
fungus
Ever heard of the 'switch' statement?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
fungus
(edit: typo)
I agree.
Plus ... you won't have five clicks on the dial where nothing happens.
Far-seeker
Yes, but a case-switch block involving seven cases, or even just six if one color is used as a default case, is going to be about the same size as a nested if-then-else block.  :P
