I have been trying to integrate my voltage reference code into my touch screen code, the voltage reading changes when a fresh page is loaded but not if left on one page and pot is adjusted.
See voltage reference below, which when run on its own, the voltage displayed changes with the adjustment of the pot
#include <UTFT.h>
extern uint8_t BigFont[];
const int systembattpin = A8; // pin that the sensor is attached to
const int controlbattpin = A9;
float voltage1 = 0;
float voltage2 = 0;
UTFT myGLCD(ITDB32S,38,39,40,41);
int x, y;
// Initial setup
myGLCD.InitLCD(PORTRAIT);
myGLCD.clrScr();
myGLCD.setBackColor(255, 255, 255);
// read the input on analog pin 8:
int sensorValue = analogRead(A8);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage1 = ((sensorValue * 1.68) * (5.0 / 1023.0));
myGLCD.setFont(BigFont);
myGLCD.setColor(0, 0, 255);
myGLCD.print("System battery", CENTER, 50);
myGLCD.printNumF(voltage1, 1, CENTER, 100, '.', 3, ' ');
// read the input on analog pin 9:
int sensorValue1 = analogRead(A9);
float voltage2 = ((sensorValue * 1.68) * (5.0 / 1023.0));
myGLCD.print("Control battery", CENTER, 150);
myGLCD.printNumF(voltage2, 1, CENTER, 200, '.', 3, ' ');
So why does this not happen when it is integrated into my main code?
Is it the way i have constructed my menu code?
Do i need function to check whether the voltage has changed and if so update/refresh?
See main code attached, as its too long to post
The voltage reading is calculated in void getbattstatus() which is called by void statusbar2(), is this the wrong way to go about it, any help would be grateful, as this will help with integrating time and date code
Thanks in advance
