Hi marque!
i'm trying the new update.what i see at first look is that:
1. in settings,every profile has a little typo in adress name (adres)
2.in settings,the name "application settings has a little typo (aplication)and also in the box inside when you click
3. the previous release problem of name inverted is still here.i mean,when you want to write a label on buttons for each coloumn(3 in total)you have:
first coloumn parameters..and is ok
second coloumn parameters---and it's ok because it act directly to second coloumn's settings,but it's labelled third colomn instead of second.
of course also the third is switched,you have only to switch 2 name.
Like you see i reported only very little bugs related only to grammatical and logic things.
I'll report as well if find something wrong!thanks for the hard work XD
ps--can you reply on what i asked you 2 post ago?here below pasted :
"can you point me out what kind of use i can do with b and c square box?what do i have to write there?"
