Topic: Arduino Controller android app (Read 102126 times) previous topic - next topic
marque
Now there is a new version with three seekbars. With these seekbars it is easier to control RGB leds, motors and servo's.
RB
Awesome!
Question: will upgrading delete/overwrite all my existing profiles?
Thanks,
R
marque
#62
Jul 31, 2013, 12:08 pm Last Edit: Jul 31, 2013, 02:02 pm by marque Reason: 1
Quote
No, but........
I recommend a backup. 8)
On uninstall / reinstall your settings will be deleted.
On rooted phones, your settings are saved in the XML file in data/data/com.marquesoft.arduinocontroller/shared_prefs.
I am looking for a way to import / export profiles, but it need some more testing and debugging.
guizdm
Hello everybody,
Does someone have a complete and working code to Arduino Mega with W5100 ethernet board to work with Arduino Controller android app? There are a lot in the forum, but no one is complete or perfectly working.
Thanks!!!
marque
Hello everybody,
Thanks!!!
The one from the first post should be working?  What's the error you get?
marque
New update coming this week. Possibility added for export and import of profiles.
marque
The paid version has had a big update today.
• Now it's possible to import, export and share the profiles
• In program mode it's easy to set up the profiles
• In program mode Click button to edit the button text
• Long click in program mode to edit the datastring send to the arduino
• In the default import folder there are two example profiles to use with the example arduino code
• There is a new example arduino code in the openings post
• Reset function added to remove all settings and start from scratch
• Option added to send the seekbar values on every change for quick response
• More to come!
marque
HI Marque
Is it possible through the Arduino Sketch to alter the size of the window at the top of the page?
Or is it pre programmed in to the Android App?
Thanks
Rich
The size of the webview on top depends on the response of the arduino.
However it is possible to hide this webview on the layout.
marque
Hi Marque
Thanks for the excellent app very useful and easy to adapt to my needs.
Is it possible to make any login to access to the application for security reason (I like close and open a door, switch off on alarm, ..).
And is it possible in settings button for reset change to button for save configuration, because I use this app to access to different arduino board with different functionality.
thx
Thanks in advance
Lesz
It is possible to set a password to start the application.
Quote
You can set eight different profiles in the application to control eight different arduino's.
It is possible to export the profiles to your SD card for back up purposes and restore them to the application, or just send / share the profiles by mail to your friends.
marque
Today the free version has had the big update too.
• More to come!
drksam
Hi. Love the app. Is there a reference page any where that would list the arduino functions that are used and is there a way to have the client update periodically while the app is running?
Arduino UNO, mega 2560, atmega328, attiny44, LCD, TFT, touch, SD, i2c, spi, MCP23017, android control, automation direct PLCs and drives.
marque
#72
Aug 20, 2013, 09:22 pm Last Edit: Aug 20, 2013, 10:00 pm by marque Reason: 1
Nice to hear you like the app.
Some of the functions in the example sketch have a comment about their functions but all they do is set a value to a integer and print it back to the client and to the serial interface. What you do with them is up to you.
I uploaded a new arduino example sketch with a new function which works with "X" from "example profile 2" in the android app. It shows how to update the data every second. Please let me now if this is what you mean.
marque
I opened a new topic to exchange the exported profiles.
Share your profiles and sketches in this topic
drksam
Quote
Yes this works great for what i need thank you.
