Topic: Arduino Controller android app (Read 102245 times) previous topic - next topic
BobbyD
RichieC,
I noticed that in case 9 where you switch everything on , you don't have a  ;break:
case 9: digitalWrite(GasBoiler, HIGH);digitalWrite(HeatPump, HIGH);digitalWrite(UndFlor, HIGH);
/* Basically a call for all Heating on */
Should it be:
case 9: digitalWrite(GasBoiler, HIGH);digitalWrite(HeatPump, HIGH);digitalWrite(UndFlor, HIGH);break;
Just wondering if things may hang after a case 9 is issued ?
Bob
Frit
Hi Marque.
Any chance of a sketch for a wifi connection?
RichieC
Thanks I'll change this today and see if it helps.
Thanks
Rich
marque
Hi Marque
I still using your app to control my heating but I'm having trouble. The server side of my program doesn't run for very long before stopping. The main part of my program still contuines to run but my devices won't connect to the Arduino Board.
I have attached my code for you to see if there is anything obvious.
Thanks
Richard
At the end of the sketch i see a strange part. maybe it is causing the trouble.
Code: [Select]
x=0;
if (x == 0)
  client.println(" ");
In my own programs i try to contact google.com every hour. When it fails, the arduino resets itself.
marque
Here are examples of what I see in the serial monitor no matter what buttons I press on the Android app:
Droid 4:
*CLOS**OPEN*GET /?1 HTTP/1.1
Host: 192.168.43.38:2000
Connection: keep-alive
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
X-Requested-With: com.marquesoft.ArduinoControllerPro
User-Agent: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID4 Build/9.8.2O-72_VZW-18) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30
Accept-Encoding: gzip,deflate
Accept-Language: en-US
Accept-Charset: utf-8, iso-8859-1, utf-16, *;q=0.7
Acer A500:
Host: 192.168.43.85:2000
User-Agent: Mozilla/5.0 (Linux; U; Android 4.0.3; en-us; A500 Build/IML74K) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Safari/534.30
x-wap-profile: http://support.acer.com/UAprofile/Acer_A500_Profile.xml
The "OPEN*GET /?1 HTTP/1.1" part looks Ok. The 1 after the ? should change for each button you programmed.
RichieC
Thanks I'll check my code
Quote
in my own programs every hour I try to contact google if it fails the arduino resets itself
How do you do that? Could you paste the code here please?
Thanks
Rich
marque
Thanks
Rich
Use rtc or millis to execute a networkcheck(); every hour.
Declare:
Code: [Select]
IPAddress ServerToCheck (74,125,228,32 );         //IP adress of google
char dnsServerToCheck[] = "google.com";             // set the name of the server to check
boolean networkonline = false;
boolean DNS = false;
Code: [Select]
void networkcheck()
Serial.println ("Network check");
 if (client.connect(dnsServerToCheck, 80))
   delay(300);
   Serial.print("connected to ");
   Serial.println(dnsServerToCheck);
   client.println("GET / HTTP/1.1");
   client.println();
   while (client.connected())
     if (client.available())
       char c = client.read();
       if (readString.length() < 20)
         Serial.print(c);
         readString.concat(c);
       if (c == '\n')
         client.stop();
        Serial.println("DNS OK");
         DNS = true;
         networkonline = true;
         readString="";
     if (!client.connected())
       client.stop();
       readString="";
 if (!DNS)
    Serial.println("DNS Error");
   Serial.println("Check for IP");
   if (client.connect(ServerToCheck, 80))
     delay(300);
      Serial.println(ServerToCheck);
     client.println();
            Serial.print(c);
         if (c == '\n')
           client.stop();
           Serial.println("IP lookup OK");
           Serial.println("DNS not available");
           readString="";
          Serial.println("Disconnecting");
         client.stop();
         readString="";
     Serial.println("Network Error");
   resetFunc();
void(* resetFunc) (void) = 0; //declare reset function @ address 0
Holazac
Hi will this be able to work with a WIFI shield instead of an Ethernet shield?
marque
Can you give me a example of a wifiserver code so i can modify it to work with the controller app.
chickenzown
Is it possible to import custom buttons for the app,
I use it to control a bank of relays that control various pumps / filters on my Koi pond,  a toggle button rather than one for on and another for off would be much better, giving visual feedback of the relays current state (high/low).
thanks
Ian
marque
thanks
Ian
This is already possible but you see the feedback in a line in the browserview and no indication on the button itself.
marque
#101
Aug 21, 2014, 11:09 am Last Edit: Aug 21, 2014, 11:26 am by marque Reason: 1
Coming soon!
For the Pro versions you can expect home screen Widgets very soon. There will be five different layouts:
  • horizontal
  • vertical
  • directional pad
  • up / down
  • one button
Features:
  • Resizable
  • Reconfigurable
  • Status indicator
  • Value indicator
  • last update time
  • auto update
At first widget will be a beta feature.
ruli00
Will this app work with the enc28j60 controller? I understand that the example sketch using the w5100 will not work.
Thanks
ruli00
ruli00
Thanks
ruli00
After tinkering all day I've answered my own question. I replaced the standard Ethernet library with UIPEthernet.h and all is well.
ambroz666
How can I write program where turnig on and turnig off is controlled by one button (not two buttons ON and OFF)?
My program is in supplement.
