Topic: "pins_arduino.h: no such file or directory", but it's there? (Read 3802 times) previous topic - next topic
MR_NINJA
Hi, so, I'm fairly new to Arduino (but I've gobbled up all info I could find) and I'm having trouble.
I'm doing a project that involves ATmega168s on a protoboard. I followed the tutorial (barebones), and downloaded the files and placed them in the right directories. But when I open the program and select ATmega 328 on a breadboard (8mhz) and load the blink sketch to compile it says:
"arduino-1.0.1\hardware\arduino\cores\arduino/Arduino.h:213:26: error: pins_arduino.h: no such file or directory"
Does anyone know the problem?
PaulS
I do believe that there is more than one. Which one are you referring to?
Which files? From where?
Which ones would those be?
Which program?
MR_NINJA
Sorry for not clarifying.
The tutorial: http://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
The files included in the "Minimal Circuit(Removing the External Clock)" section. I downloaded that zip.
I then placed it in the proper file directory: the "Hardware" subdirectory.
The program being Arduino.exe, the program for programming the Arduino and uploading code.
codlink
Are you finding the  "ATmega328 on a breadboard (8 MHz internal clock)" under >Tools>Board>?
If not, here is the path that it should be:  C:\Users\[youruserprofilehere]\(My) Documents\Arduino\hardware\breadboard\boards.txt
//LiNK
MR_NINJA
Yes, I am finding it under the tools>boards menu.
so...
codlink
//LiNK
codlink
#7
Oct 21, 2012, 04:29 am Last Edit: Oct 21, 2012, 04:37 am by codlink Reason: 1
Try adding this line at the end of the boards.txt file:
atmega328bb.build.variant=standard
Or if that doesn't work, try this one:
atmega328bb.build.variant=arduino:standard
//LiNK
