So my friend gave me his Traxxas remote control car about a month ago and I thought it would be really cool to get it to run using a PS2 controller. I was able to use Bill Porter' s library (PlayStation 2 Controller Arduino Library v1.0 « The Mind of Bill Porter) and two xbee radios. So having little knowledge of the arduino I set out to make it happen.
I got the car running and I am able to send data and move left and right using one analog stick and forwards, backwards with the other. But I wanted to have a little more control of the rear servo. (the analog stick is really sensitive).
So for the last few days I have been looking and trying to write some code that would allow me to hold down the "X" button and count up from 90 to 179 and the the "o" button and count down from 89 - 0. What I got kind of work, but I need to be able to control the speed at which the loop loops. The problems start to happen when I send data and do other things it start to slow down and the loop will not loop fast enough. Any ideas/help will be greatly welcome, and I also have issues once im done holding the button down. ie getting the servo back to 90 and or just starting over.
sorry for the grammar,spell...
Thanks Tom.
Data sending is as follows
255 = rev
254 = forward
253 = left and right
252 = all stop
//PS2 Contoller
#include <PS2X_lib.h>
//LCD Libary
#include <LiquidCrystal.h>
//Declare Varables
//fermware versions
char ConVer[] = {"oct17d"};
//PS2
PS2X ps2x;
byte vibrate, type;
int error;
//LCD
LiquidCrystal lcd(12, 11, 10, 4, 3, 2);
int RX;
int RY;
byte LX;
int LY;
int all_stop = 90;
/*speed timer*/
boolean button_state = false; // button_state sets the button pressed or not pressed
//fwd/rec limits
byte fwd_max = 179;
byte fwd_min = 91;
byte rev_max = 0;
byte rev_min = 89;
byte still = 90;
//timing
unsigned long previous_millis = 0;
unsigned long current_millis;
//spd
byte fwd = 91;
byte rev = 89;
/*MENU*/
int interval = 60;
int rssiPin = 9;
byte rssiDur;
/*start program and seial connection*/
Serial.begin(9600); //open data port/start sending data over xbee
error = ps2x.config_gamepad(8,6,7,5, true, true); //(clock, command, attention, data, Pressures?, Rumble?) returns 0 when found 1 if not found
if(error == 0)
lcd.begin(16,2);
lcd.setCursor(0, 0);
lcd.print("Found Controller"); //displays on the lcd if the contoler is found
lcd.setCursor(0, 1);
lcd.print("PS2_Ver: "); //displays version of controller
lcd.print(ConVer);
delay(750);
else if(error >= 1)
lcd.print("Not Found");
lcd.clear();
pinMode(9,INPUT);
ps2x.read_gamepad(); //reads controller for the duration of the loop
/*ALL STOP
if(ps2x.Button(PSB_PINK)) //failsafe
Serial.write(252);
lcd.print("ALL STOP");
delay(50);
lcd.clear();
return;
/*MENU*/
menu();
/*FORWARD*/
if(ps2x.Button(PSB_BLUE))
drive_fwd();
else if(ps2x.ButtonReleased(PSB_BLUE))
fwd = still;
LX = 90;
/*REV*/
if(ps2x.Button(PSB_RED))
drive_rev();
else if(ps2x.ButtonReleased(PSB_RED))
rev = still;
LX = 90;
Serial.write(254);
Serial.write(fwd);
LX = map(ps2x.Analog(PSS_LX),0,255,0,179);
Serial.write(253);
Serial.write(LX);
/*This is the start of the controls*/
/****control fwd via "x" button*****/
void drive_fwd()
//reads x button state
current_millis = millis(); // take current time
unsigned long time_lap = current_millis - previous_millis; // gives different between time
if(time_lap > interval)
previous_millis = current_millis; //saves the last time you steped up servo speed
fwd++;
constrain(fwd, still,fwd_min);
if(fwd < fwd_min)
fwd = still;
else if(fwd >= fwd_max)
fwd = fwd_max;
lcd.print(fwd);
/*control rev via "o" button*/
void drive_rev()
rev--;
constrain(rev, still,rev_max);
if(rev > rev_min)
rev = still;
else if(rev <= rev_max)
rev = rev_max;
lcd.setCursor(4, 1);
lcd.print(rev);
/*ANOLOG STICKS*//*STEARING
void sticks()
left stick
// lcd.print("L");
LY = ps2x.Analog(PSS_LY); // reading left Y axis
constrain(LY,0,179);
// lcd.setCursor(1, 0);
lcd.print("Y");
lcd.print(LY);
// reading left X axis and contrains it to serial output
lcd.print("X");
lcd.print(LX);
delay(100);
lcd.clear();
right stick ;
// lcd.setCursor(0, 1);
// lcd.print("R");
RY = ps2x.Analog(PSS_RY); // reading RIGHT Y axis
constrain(RY,0,179);
// lcd.setCursor(1, 1);
lcd.print("Y");
lcd.print(RY);
RX = ps2x.Analog(PSS_RX); // reading RIGHT X axis
constrain(RX,0,179);
// lcd.setCursor(7, 1);
lcd.print("X");
lcd.print(RX);
Menu*/
void menu()
if (ps2x.Button(PSB_PAD_UP)) //changes acceleration and contains it with 2-10 seconds
interval = constrain(interval - 1, 10, 60);
delay(100);
if (ps2x.Button(PSB_PAD_DOWN))
interval = constrain(interval + 1, 10, 60);
delay(100);
int interval_percent = map(interval, 10, 60, 99, 10);
lcd.setCursor(10,1);
rssiDur = pulseIn(rssiPin, LOW, 200);
lcd.print(rssiDur);
lcd.setCursor(13, 1);
lcd.print("%");
lcd.print(interval_percent);
