0
Offline
Newbie
Arduino rocks
« on: October 17, 2012, 11:17:30 pm » |
I am running Win& (32bit) and find that it will not recognize my new Uno R3. After some research, I tried in on a different computer and was able to get it work and was able to program it. Switching back to my Win7 machine, It is not recognized. Checking device manager shows no unknown devices. Any ideas on beating my Win7 into submission?
Thanks
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #1 on: October 17, 2012, 11:58:19 pm » |
Have you tried a USB cable known to be good?
Have you tried a different USB port?
Does the computer make the "device insertion" sounds when you connect the board?
Logged
0
Offline
Newbie
Arduino rocks
« Reply #2 on: October 18, 2012, 03:20:15 pm » |
Yes the cable is good. I have used it with the Uno on an XP machine successfully. Also tried different USB ports with no effect. The computer does make the usb connect sound when the cable and device is plugged in. Have also tried rebooting. The computer does work with Leonardo and earlier versions of Arduino.
Thanks
Logged
Chile
Offline
Edison Member
Arduino rocks
« Reply #3 on: October 18, 2012, 03:20:50 pm » |
Logged
0
Offline
Newbie
Arduino rocks
« Reply #4 on: November 18, 2012, 11:42:58 pm » |
Installed the enhanced release IDE, but it is sitll not being recognized by my Win7 32 bit machine. Checked the device manager and no new devices seen. The computer does make the usb connection sound but that is about the limit of it.
Logged
Chile
Offline
Edison Member
Arduino rocks
« Reply #5 on: November 19, 2012, 06:13:13 am » |
Are you sure the board is working just right now? can you test it again in the xp machine?
Logged
Westminster, Co.
Offline
Newbie
« Reply #6 on: November 20, 2012, 05:09:37 pm » |
I am very new at this and was directed here because of my problem with Windows 7 not recognizing Arduino Uno R3. What I found here is not much in help with particular solutions. While stumbling through different comments, and hoping for a tidbit of info as to solve my problem, I found a solution in that, what seems that others here too were having this problem, having Windows 7 forced to recognize Arduino Uno R3. Sorry for this solution being redundant if this has been suggested before, it is only that the search I did pointed me here, and found nothing to help. There is the importance to have download the file for programming the Arduino boards.
1) In Windows, the device manager indicates an "Unknown Device." 2) Hovering the mouse over "Unknown Device", right click and choose "Properties." 3) A window pops up displaying three tabs (to know you are in the right area). Under the "General" tab click the button "Update Driver." 4) Another window pops up and gives you two choices, a) have the computer look for update drivers; and b) browse manually for the drivers, click "manually look for drivers". 5) Another window pops up to direct you to the folder for the new drivers. At the bottom of this window there is a green arrow pointing to "Let me pick from a list." (This action is not updating drivers per say, but telling Windows 7 to add a device and therefore add the drivers). Click on this button. 6) The next window lists devices already in Windows database. At the top of this list "Show all devices" should be highlighted, if not highlight it by clicking on it. At the bottom of this window click "Next". 7) The next window again lists Manufacture and Model. At the bottom there is a button with "Have disk". Click this button. 8) As stated above, maneuver to the folder that you have downloaded from Arduino's web site in which you have installed. Within this folder there is a subfolder called "Drivers". In drivers there is a file called "Arduino Uno REV3" (among others). 9) Clicking this file will solve the "Unknown Device" and Windows will recognize your new Arduino board.
I hope this helps those with the same problem as I have had.
Moderator edit: turned off smileys
« Last Edit: March 23, 2013, 02:49:53 pm by Coding Badly »
Logged
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #7 on: November 20, 2012, 08:16:10 pm » |
After Step 2 click on driver tab, click on update driver box, click on browse, drop down the selection window and navigate to a path similar to this ""C:\Program Files (x86)\arduino-1.0.1\drivers"" and then click on next. This is how my drivers are installed, from one of my serial ports used for a Mega, I have both installed and working at the same time.
Bob
« Last Edit: November 20, 2012, 08:18:14 pm by Docedison »
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Portland, OR
Offline
Newbie
« Reply #8 on: March 23, 2013, 09:08:15 am » |
truthseer - Your directions were Extremely helpful. I know I'm a bit late, but thank you!
Logged
Offline
Newbie
« Reply #9 on: March 25, 2013, 06:10:25 pm » |
I had problems with windows uno7 home premium recognizing my o uno rev 3. Using truthseer's instructions i was able to install the drivers and then had to switch the arduino from com port 7 to com port 1. My problem know is that i am given a code 10 from microsoft. Code 10 is described as "this device cannot start" any idea for my next move? Thanks!
Logged
Offline
Newbie
« Reply #10 on: April 11, 2013, 02:18:43 am » |
Absolute Genius. Installing the driver worked. in Windowz 8 64bit. Thanks a lot.
Logged
NZ
Offline
Newbie
« Reply #11 on: April 13, 2013, 12:02:58 am » |
Hi, Have the same problem as you had, have followed your (very clear ) instructions, but no joy. I get as far as step and click "have disk",next window says "instal from disc" .I am baffled.
Logged
Austin, TX
Offline
Sr. Member
carpe diem
« Reply #12 on: April 13, 2013, 02:07:02 pm » |
I have created a driver installation utility to simplify the driver installation process on Windows.
Download the attachment and launch it. Just follow the prompts then plug in your Arduino.
If all goes as planned, your Arduino should show up with a com port assigned without any further interaction.
Let me know how it goes.
« Last Edit: April 14, 2013, 06:15:49 pm by Louis Davis »
Logged
Offline
Jr. Member
« Reply #13 on: April 13, 2013, 10:19:54 pm » |
Also consider trying a different USB cable. A bad cable could cause problem like what you're describing.
Logged
NZ
Offline
Newbie
« Reply #14 on: April 14, 2013, 05:48:06 pm » |
"Exasperated", Tried downloading your attachment, my computer said, I quote, "Arduino driver installer exe, is not commonly downloaded and could harm your computer, Delete Actions Downloads". wont let me download.
Logged
