Topic: Microsoft Visual Studio - 100% Arduino Compatibility. Producers vs Hackers! (Read 18746 times) previous topic - next topic
visualmicro
The Arduino plugin for Microsoft Visual Studio provides 100% compatibility with the Arduino IDE, is very easy to install, very solid and reliable to use and is designed for both new Arduino users and experts. This plugin removes all of the complexities of using a professional development tool, it makes Arduino development very easy!
This thread will be used to make a number of exciting new feature announcements over the coming weeks. You can read reviews from all types of users on the web, a collection of reviews from our forum members can be found here
A short summary of some distinguishing features is shown below, many features are currently unique to this plugin:-
  • Simple install, just enter the location to an arduino.exe
  • Supports ALL Arduino projects
  • Switch Arduino board without configuration changes
  • Supports multiple pde/ino (arduino sources) files per sketch (same as the Arduino IDE)
  • Compiles projects that contains multiple pde/ino sources in the correct order
  • Immediate and automatic update of intellisense at all times. (eg: add library, switch board, add method to .pde/cpp etc..)
  • Ultra fast compilation. The Arduino IDE has started to adopt some of our speed improvment ideas. Cool!
  • Provides double click drill down from compiler errors into all source code (multiple .pde/ino, libraries)
  • Compiles exactly the same way as the Arduino IDE. Ensures projects adhere to the same rules as the Arduino IDE.
  • Full help and examples system (more than the Arduino IDE)
  • Supports additional non-arduino cores (same as the Arduino IDE)
  • Additional option to clone an Arduino example or open a single example source code
  • Automatically provides examples for all libraries (where available)
  • Optionally toggle visibility of Arduino libraries in each project (for easy edit and/or learning)
  • Automatic project creation and detection of Arduino sketch files
  • Automatic validation of sketch projects each time they are opened
  • Multiple Arduino projects per solution
  • Supports both usb and programmer (isp) upload
  • Option for a unique and fully integrated breakpoint debugger. No additional hardware required.
  • Well documented with a professional forum. Please join
The plugin works only with Microsoft Visual Studio Professional and above which can be obtained free for 3 years from here
The unique debugger option is currently being beta tested by approx. 250 users. Join our forum and request a free copy!
The plugin is free and works with Visual Studio 2008,2010 and 2012. Visual Studio 2012 is recommended because it opens very quickly, it opens faster than the Arduino IDE!
Arduino for Microsoft Visual Studio Pro and Atmel Studio 6.1 http://www.visualmicro.com
Arduino Debugger http://www.visualmicro.com/post/2012/05/05/Debug-Arduino-Overview.aspx
visualmicro
#1
Oct 22, 2012, 10:10 pm Last Edit: Oct 23, 2012, 06:14 pm by Visual Micro Reason: 1
Automate Your IDE - Single Click Arduino Commands
Making the IDE work better for you by adding your own quick access Arduino tool bars, buttons, menus and shortcut keys to automate the various Arduino IDE functions can be a lot of fun.
The Visual Studio Plugin automatically provides every Arduino command, serial port, board and programmer as standard Macros that can be used to customize or automate the IDE.
An example might be adding a button that burns a bootloader or uploads using a certain ISP/Serial port to a particular Arduino Board. Any single Arduino command or combination of commands can be assigned to buttons, menus and keys
Russia
Hodel has long create my IDE, but there was no time ...
Standard IDE terribly slow, the brakes increased in proportion to the number of COM ports on the system.
Visual Studio 2012 is installed on Windows 8 opens as a notepad even a Tablet PC.
Many thanks for the plug-in to the studio.
Compiling the sketch several times quicker. Adjusted tool bar with the right buttons for me everyday use. IDE from arduino.cc died for me probably forever.
ambuj
same thing i have done with visual studio 2010 in windos Xp.
i am able to compile all code and all library expect usb2.0 which developed by oleg it show me too much error.
and all error come due to undefined variables. in my opinion it happens because it did not get header file but it happens only usb library.
and most horrible thing is if i am trying to compile ADB library then it working fine. so as of now i dont know what i have to do any suggestion how could i compile usb library?
This is USB library link
https://github.com/felis/USB_Host_Shield_2.0
visualmicro
Hello, thank you for the good information
It compiles correctly for me (see below). Which example are you trying to compile?
Are you using arduino 1.0.1?
Does your project compile correctly in the arduino ide without error?
Thanks
visualmicro
#5
Oct 26, 2012, 04:49 pm Last Edit: Oct 27, 2012, 02:20 am by Visual Micro Reason: 1
I have found something interesting with this library if you use Verbose/Warnings settings.
This library causes 100's of warnings like the ones shown below. So many warnings cause it to take a few minutes to compile but it does compile okay.
If you have switched on "Verbose" or "Warnings" in the options I suggest that you switch them OFF again...
Tools>Options>Visual Micro>Compiler>Verbose = False
Tools>Options>Visual Micro>Compiler>Warnings = False
The example I tested, it does compile correctly. BUT, it produces so many warnings it looks like a bad error. but is not  :)
message.h : Warning: only initialized variables can be placed into program memory area
parsetools.h : pBuf will be initialized after nStage
parsetools.h : arLenCntdn will be initialized after arLen
confdescparser.h : : In member function 'void ConfigDescParser<CLASS_ID, SUBCLASS_ID, PROTOCOL_ID, MASK>::PrintHidDescriptor(const USB_HID_DESCRIPTOR*)':
confdescparser.h : Warning: only initialized variables can be placed into program memory area
Compile OK
NB: You will see the same output in the Arduino IDE if you switch on "ArduinoIDE>File>Preferences>Verbose". So this library is best used without these settings in both Visual Studio and the Arduino IDE
ambuj
Thanks for replay,
same example i am trying. that is blink_led.
No i am using Arduino 1.0.0 IDE
Yes my project compiles correctly in Arduino IDE
And also i getting error not warnings.
This is by default in my system i never changed even i also tried to make true but nothing special for me
ambuj
if i am using Arduino 1.0.1 IDE then it's working for me
westfw
OK, I'm curious.  Could this be made to work using the pieces of Visual Studio that are installed when you put "Atmel Studio" on your computer?
visualmicro
#9
Oct 27, 2012, 06:11 pm Last Edit: Oct 27, 2012, 06:43 pm by Visual Micro Reason: 1
@ambuj.
1)
Are you saying that Visual Studio compiles this project correctly for you with the Arduino 1.0.1 IDE?
2)
There was a problem with Arduino 1.0.0 and Visual Studio?
Thanks
visualmicro
#10
Oct 27, 2012, 06:41 pm Last Edit: Oct 27, 2012, 09:06 pm by Visual Micro Reason: 1
@westfw Good question.
I have made as much of this plugin (all the arduino stuff) a separate api and have ensured that all the Arduino/Project settings are not tied to any Visual Studio settings. So actually it could work with any IDE in the future.
Although Atmel Studio lacks a lot of the nice features of normal Visual Studio systems it isn't that far away in terms of what it might do for us. Much of the user interface provided by the plugin would probably work "as is" with Atmel Studio it might only be the areas that modify VS CPP properties (to detect Arduino sources and set board properties) that would need to change. This is an easy change because VS 2008 and VS 2010 use different CPP systems so the code is already conditional in this area. However with the proper support from Atmel we could really tap this stuff into their IDE and integrate it fully.
The problem is that Atmel are not a proactive company and their developer support is poor. I only have a few questions for them and have approached them a number of times. Each time I have been promised that developer support is planned for some future time. Not very helpful! I am sure I could work it out by myself but time is the limiting factor.
If anyone would like to help with the understanding of the Atmel side of things I would be more than happy to give it a go sooner rather than later.
So far, this project has cost a lot of time and money which makes it difficult to justify the addtional time for Atmel studio right now. For obvious reasons there is no support for this project from Arduino or Microsoft  :) This is why the new Arduino debugger tool is not going to be free (but is free and in beta at the moment). I hope the revenue from the debugger funds the time and provides the motivation to make this plugin work with Atmel Studio.
ambuj
@Visual Micro,
1)
2)
1)
yes it's happens with me it strange but true
may be i m doing some thing wrong with it.. :P
2)
May be i am not sure
But in opinion it has because when i tried to work with(Arduino 1.0.1) then i just change the path for new Arduino version and it work perfectly i dont know what is going on with it.
And the bed thing is when i try to compile any other library to visual studio 2010 with Arduino 1.0.0 so it's work perfectly but for USB library it not working
when i complies with arduino 1.0.1 this time every single library working fine.
Second bed thing for me this is first time when i m using visual studio so if you have any tutorial for debugging then it's good for me.
visualmicro
#12
Oct 29, 2012, 07:22 pm Last Edit: Nov 17, 2012, 12:43 pm by Visual Micro Reason: 1
Hi, we have small language communication problems  :)
1) Usb Lib
I will try the library on arduino 1.0 but I think you are happy using 1.0.1? Everything works okay for you?
2) Debugger
Please "Register" on visualmicro.com. When you register include a request to join the debugger beta team. You will then be given more instructions for the debugger.
The are many documents on visualmicro.com about the debugger, there is a small wiki and also this overview
Debugger on YouTube
After the beta program ends, only registered beta testers will be given a free debugger license
visualmicro
#13
Nov 17, 2012, 12:54 pm Last Edit: Nov 17, 2012, 06:14 pm by Visual Micro Reason: 1
Reminder, the team testing the new Arduino debugging tool has grown to 400+ users. If you would like to join the team and receive a free license for this tool then sign up for the forum on http://www.visualmicro.com and include a request to join the debugger beta team.
The free Visual Studio plugin is the only 100% compatible plugin for Arduino. After installing Microsoft Visual Studio Professional you will have compiled your first Arduino sketch in under 10 minutes.
Compiles any Arduino sketch at the click of a button. Allows you to see what your Arduino is doing and why, discover what hardware is connected to your Arduino using I2c, Digital and Analog graphical displays. Includes hundreds of other features such as Arduino memory free memory and runtime memory usage reporting.
Includes support for Teensy and other non-arduino cores.
Visual Studio Professional can be obtained free for over 3 years. Read more here
pito
I've tried to set mpide-0023 as the arduino path with no luck.
Is there a chance to enhance it to chipkit as well?
http://www.chipkit.org/forum/viewforum.php?f=6
