Offline
Newbie
« on: October 19, 2012, 11:30:46 am » |
Hello, I'm having some difficulty reading the MAX6682 digital output. Does anyone have the sketch for it? I don't know how to properly read the 10-bit considering that the 3 LSBs of the output code represent fractional temperatures. http://www.maximintegrated.com/datasheet/index.mvp/id/3319
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #1 on: October 19, 2012, 03:10:40 pm » |
Just take the value and divide it by 8 (to get whole degrees) or 8.0 to get a floating-point number that includes the fractions of a degree.
Logged
United Kingdom
Online
Faraday Member
« Reply #2 on: October 19, 2012, 04:37:48 pm » |
I have used code similar to this in the past, with the MAX6682 connected to the SPI pins: const int csPin = 10; // digital pin used for MAX6682 CS
int pollSensor() { // Pull CS low and read out result of last conversion digitalWrite(csPin, LOW); int hiByte = (int)(signed char)SPI.transfer(0); // read high 8 bits and sign-extend uint8_t loByte = SPI.transfer(0); // read low 4 bits + 4 dummy bits int reading = (int)(((unsigned int)hiByte << 3) | ((unsigned int)loByte >> 5)); // combine bytes // Set CS high again to allow other devices to use bus and tell the MAX6682 to start a new conversion digitalWrite(csPin, HIGH); return reading; }
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline
Newbie
« Reply #3 on: October 22, 2012, 09:03:49 am » |
Thanks for the replies. I keep having problems. This is the first time I am working with the Arduino and do not know much about programming! ... Anyway... I would like to get temperature values with the highest resolution possible ie 1LSB = 0.125 º C. How can I do it? #include <SPI.h> #define CS 53 //Selection Pin #define MISO 50//MISO #define SCK 52//Clock int readvalue;
void setup(){ Serial.begin(9600);
//set pin modes pinMode(CS, OUTPUT); pinMode(MISO, INPUT); pinMode(SCK, OUTPUT); SPI.begin(); // initialize SPI, covering MOSI,MISO,SCK signals SPI.setBitOrder(MSBFIRST); // data is clocked in MSB first SPI.setDataMode(SPI_MODE0); // latched on rising edge, transitioned on falling edge, active low }
int MAX6682() { // Pull CS low and read out result of last conversion digitalWrite(CS, LOW); int hiByte = (int)(signed char)SPI.transfer(0); // read high 8 bits and sign-extend uint8_t loByte = SPI.transfer(0); // read low 4 bits + 4 dummy bits int reading = (int)(((unsigned int)hiByte << 3) | ((unsigned int)loByte >> 5)); // combine bytes // Set CS high again to allow other devices to use bus and tell the MAX6682 to start a new conversion digitalWrite(CS, HIGH); return reading; }
void loop() { double Dout; double out; double Vext; // double R = 7680.0; // Fixed resistance in the voltage divider // double Rt; // Computed resistance of the thermistor Dout = MAX6682(); Serial.print("digital out "); Serial.println(Dout); out = Dout*0.125; Serial.print("out "); Serial.println(out); Vext = 1.2370 *(Dout*0.010404/8 + 0.174387); Serial.print (Vext); Serial.println(" volts"); Serial.println(""); delay(1000); }
Logged
United Kingdom
Online
Faraday Member
« Reply #4 on: October 22, 2012, 09:49:34 am » |
You haven't said what problems you are having. When you run the program, what does it print? Does what it prints depend on the temperature?
Logged
Santa Fe
Offline
Full Member
« Reply #5 on: October 22, 2012, 09:58:38 am » |
Also, does the shield you are using drop the voltage from the digital outputs on the Arduino to around 3.3 volts into the 6682?
Logged
United Kingdom
Online
Faraday Member
« Reply #6 on: October 22, 2012, 10:41:30 am » |
The MAX6682 is specified for Vcc up to 5.5V, so that isn't necessary, unless the MAX6682 has been powered from the 3.3V Arduino pin.
Logged
Offline
Newbie
« Reply #7 on: October 22, 2012, 11:02:22 am » |
Yes the output depends on the temperature: digital out 183.00 out 22.87 0.51 volts
digital out 186.00 out 23.25 0.51 volts
digital out 228.00 out 28.50 0.58 volts
digital out 229.00 out 28.62 0.58 volts
digital out 212.00 out 26.50 0.56 volts
according to the datasheet: Dout = (Vrext / Vr+ - 0.174387) * 8 / 0.010404
but the value of Vrext computed does not match with the value I read with the multimeter. I'm powering the MAX6682 with the arduino 5V pin.
Logged
Santa Fe
Offline
Full Member
« Reply #8 on: October 22, 2012, 06:37:41 pm » |
Sorry LMVN, Looks like the MAX6682 has no problem with 5 volt inputs... I was thinking of the MAX6675 which needs 3.3 volts
Logged
Offline
Newbie
« Reply #9 on: October 23, 2012, 05:15:48 am » |
Nevertheless, the value of Vr+ is not 1.220 V as stated in the datasheet. The value I read is 580 mV...
Logged
United Kingdom
Online
Faraday Member
« Reply #10 on: October 23, 2012, 07:36:36 am » |
The MAX6682 only powers Vr+ up while it is taking a reading. What value are you using for Rext, and what thermistor are you using?
Logged
Offline
Newbie
« Reply #11 on: October 23, 2012, 08:37:44 am » |
Rext = 6800 ohm Thermistor 10 k ohm (AVX - NB20K00103KBA )
Logged
United Kingdom
Online
Faraday Member
« Reply #12 on: October 23, 2012, 10:06:57 am » |
When the resistance of thermistor is 10K, the reading should be ((6.8/(10 + 6.8)) - 0.174387)) * 8 / 0.010404, which comes to 177. That's not far from the values you reported. What was the thermistor temperature or measured thermistor resistance when you got the reading of 183?
Logged
Offline
Newbie
« Reply #13 on: October 23, 2012, 10:58:18 am » |
The thermistor is at 27.6 ºC, the thermistor value is 9125 ohm so the expected Dout = 194... I'm getting Dout = 189, for this situation (using the code below) the computed temperature is 26.57 ºC. #include <SPI.h> #define CS 53 //Selection Pin #define MISO 50//MISO #define SCK 52//Clock int readvalue;
//set pin modes pinMode(SS, OUTPUT); pinMode(MISO, INPUT); pinMode(SCK, OUTPUT);
int MAX6682() { digitalWrite(CS, LOW);// Pull CS low and read out result of last conversion
int hiByte = (int)(signed char)SPI.transfer(0); // read high 8 bits and sign-extend uint8_t loByte = SPI.transfer(0); // read low 4 bits + 4 dummy bits int reading = (int)(((unsigned int)hiByte << 3) | ((unsigned int)loByte >> 5)); // combine bytes digitalWrite(CS, HIGH); // Set CS high again to allow other devices to use bus and tell the MAX6682 to start a new conversion return reading; }
void loop() { float Dout; float Rntc; float Vext; float Dref; double Rth; double Rfix = 6800; double Beta = 3630; // [K] Parámetro Beta de NTC double R0 = 10000; double T0 = 298.15; float TempK; float TempC; double xx; Dout = MAX6682(); Serial.print("digital out "); Serial.println(Dout);
Dref = ((6.8/(9.125 + 6.8) - 0.174387)) * 8 / 0.010404; Serial.print("expected digital out at 25 C => "); Serial.println(Dref);
Vext = 0.52 *(Dout*0.010404/8 + 0.174387); Serial.print("Vext = "); Serial.print (Vext); Serial.println(" volts"); // Rntc = (Vext*6800)/(0.52-Vext); Rntc = ((Rfix * 0.52)/Vext - Rfix); Serial.print("NTC "); Serial.print(Rntc); Serial.println(" ohm");
TempK = Beta/(log(Rntc/R0)+(Beta/T0)); Serial.print("Temperature "); Serial.print(TempK); Serial.println(" Kelvin"); TempC = TempK - 273.15; Serial.print("Temperature "); Serial.print(TempC); Serial.println(" Celcius"); Serial.println(" ");
delay(1000); }
output: digital out 189.00 expected digital out at 25 C => 194.24 Vext = 0.22 volts NTC 9383.48 ohm Temperature 299.72 Kelvin Temperature 26.57 Celcius
« Last Edit: October 23, 2012, 11:37:39 am by LMCM »
Logged
United Kingdom
Online
Faraday Member
« Reply #14 on: October 23, 2012, 11:50:07 am » |
1. How accurate is your 6k8 resistor, and how accurate is your multimeter? Your thermistor has a tolerance of +/- 10%, so that alone would account for the error, unless you are you have an accurate measurement of the resistance.
2. Do you have the required 0.1uF decoupling capacitor, connected very close to the MAX6682 ?
3. Is the ground side of the thermistor connected as closely as possible to the MAX6682, or is it sharing a ground wire that supplies power as well?
4. To check the accuracy of the MAX6682, you could replace both the thermistor and Rext by 1% tolerance resistors of the same value (about 10K each), and compare expected and calculated readings.
Logged
