Topic: Lowest Arduino Power consumption (Read 5721 times) previous topic - next topic
tim7
I took a quick look at some datasheets for a few 3V lithium coin cells.  The ones I looked at quoted self-discharge rates around 0.1uA.
Duracell claim a self-discharge rate equivalent to 10uA in their Alkaline AA cells.
Wrend
#16
Oct 21, 2012, 06:45 pm Last Edit: Oct 21, 2012, 06:48 pm by Wrend Reason: 1
For low self discharge NiMHs, check out Eneloops. They're the only AA and AAA cells I use anymore.
For a cell that you want to last at least several years, the lithium primary ones are probably the way to go.
dhenry
I could get a 16MHz 5V Arduino down to approx 1uA.
If you could get the avr to run on a 16Mhz crystal with less than 1ua, you should contact Atmel, :)
Getting an avr to run below 50ua is easy, even on a crystal. Getting it to run below 10ua on a crystal is difficult. Getting it to run below 1ua on a crystal is out of this world.
dhenry
Shouldn't those numbers include time?  0.1 uA per second / day / year?
Should those numbers include time?
Wrend
#19
Oct 21, 2012, 11:02 pm Last Edit: Oct 21, 2012, 11:08 pm by Wrend Reason: 1
They already do include time.
http://en.wikipedia.org/wiki/Ampere
Coding Badly
#20
Oct 21, 2012, 11:24 pm Last Edit: Oct 22, 2012, 12:23 am by Coding Badly Reason: 1
Assuming I did the math correctly this time, Rayovac AA Alkaline batteries have a self-discharge of 8.676 uA.
http://www.rayovac.com/Technical-OEM/~/media/Rayovac/Files/Product%20Guides/pg_battery.ashx
Wrend
#21
Oct 21, 2012, 11:52 pm Last Edit: Oct 21, 2012, 11:54 pm by Wrend Reason: 1
That seems too low.
I think the new 1800 cycle Eneloops, for example, average about 13.7µA, loosing 30% charged capacity (600mAh) after 5 years since they were charged.
Nick Gammon
The time component cancels out. For example:
Type        Capacity mAH  Discharge %/month   Self discharge (uA)
NiCD AAA         350             20                 98
If it discharges 20% in a month then it discharges (20 / 100) / (24 * 30) in an hour (assuming a 30-day month).
So, in milliamps:
350 * (20 / 100)  / (24 * 30) = 0.097
Units are:
(mA * hours) * (1/months) / (hours/month) = mA
Effectively, it represents an instantaneous current usage of 0.097 mA (97 uA).
To re-arrange the figures, assuming we draw 97 uA then this is how long it will last:
0.097 * (24 * 30) * 5 = 349.2
Units are:
mA * hours/month * months = mA * hours
More info:
Coding Badly
#23
Oct 22, 2012, 12:07 am Last Edit: Oct 22, 2012, 12:22 am by Coding Badly Reason: 1
Starting capacity: 2535 mAh
Capacity remaining after 1 year: 97%
Ending capacity: 2458.95 mAh
Difference: 76.05 mAh
Days in one year: 365.24
Hours in one year: 525,946  8,766
76.05 mAh / 525,946 h = 0.000144597 mA = 0.145 uA
76.05 mAh / 8,766 h = 0.008675802 mA = 8.676 uA
tim7
We're talking about the power saving modes, in which the CPU is stopped.  What are you talking about?
Wrend
525,946 hours in a year / 24 = 21,914 days in a year. (About 60 years.) 8)
Coding Badly
No doubt, ouch!  This is a bit more reasonable...
Hours in one year:  8,766
