Topic: Programming an ATtiny85 with Arduino Code and Arduino Uno as Programmer (Read 8274 times) previous topic - next topic
Coding Badly
There are two possibilities left...
1. There is a mistake in your wiring.
2. RESET has been disabled.
What happens to the target when you connect a low value resistor (like 220 ohms) from RESET to GND?  Does the target reset?
marian42
The setup works with another single ATtiny.
Connecting a 470 resistor between Reset and GND has no effect.
Coding Badly
Assuming the processor's Vcc is 5 volts, if the pull-up resistor on RESET is 10 K? then a 470 ? resistor from RESET to ground should bring the voltage on RESET to 0.22 volts.  0.1Vcc is the guaranteed low threshold which is 0.50 volts.  In this scenario the 470 ? resistor is guaranteed to reset the processor.
If the pull-up resistor on RESET is 4.7 K? then a 470 ? resistor from RESET to ground should bring the voltage to 0.45 volts.  Still below the threshold.
If the pull-up resistor on RESET is 4230 ? the voltage is 0.5 volts.  The lowest value that still guarantees a reset.
It seems very likely that RESET has been disabled.  To eliminate all doubt, you could try a lower value resistor.  Were I in your shoes, I wouldn't bother.
Tom Carpenter
If the reset is disabled you might want to look at this:
http://www.rickety.us/2010/03/arduino-avr-high-voltage-serial-programmer/
It is an arduino based programmer that allows you to reset the fuse bytes even if the reset pin has been disabled.
~Tom~
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
