Topic: MIDI over USB with Leonardo (Read 1 time) previous topic - next topic
intellijel
Has anyone developed a library to use the Leonardo for USB MIDI?
This is available on the Teensy but I can't figure out if it is possible to compile Teensy sketches and use Teenys libraries on Leonardo.
Nantonos
HIDUINO is intended to reprogram the serial-to-USB 16U2 or 8U2 on the Uno and suchlike boards. Perhaps it could be compiled for the main 32U4 of the Leonardo, too.
GunSolace
I second that. There is a Teensy MIDI Library available at http://pjrc.com/teensy/td_libs_MIDI.html
Maybe you'll find this LUFA alternative at http://fourwalledcubicle.com/blog/2012/08/lufa-and-the-arduino-leonardo/ workable.
I'm trying to make a simple sensory input available via usb/midi in ableton with the Leonardo (direct recognition as USB/MIDI, etcetc), but no luck so far.
Anyone tips on where to look? Spent my last 5 hours googling, but no clear simple setup/tutorial found.
bjtliveset
there is an example to programming a arduino leonardo with a Teensy library ?
