Loading...
Pages: [1]   Go Down
Author Topic: Keypad + Password ( pequeño problema)  (Read 571 times)
Alicante
Offline Offline
Sr. Member
View Profile
Code:
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <Password.h>
Password password = Password( "1234" );
LiquidCrystal lcd(12, 11, 5, 4,3 , 2);
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'#','0','*'}
byte rowPins[ROWS] = {6, 7, 8, 9};
byte colPins[COLS] = {14, 15, 16};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  lcd.begin(16, 2);
void menu(){
  lcd.setCursor(1, 0);
  lcd.print("1.Ajust 2.Activ");
  lcd.setCursor(0, 1);
  lcd.print("3.Mem 4.Err");
//take care of some special events
void keypadEvent(KeypadEvent key){
 switch (keypad.getState()){
  case PRESSED:
    Serial.print("Pressed: ");
    Serial.println(key);
    switch (key){
     case '*': checkPassword(); break;
     case '#': password.reset(); break;
     default: password.append(key);
void checkPassword(){
 if (password.evaluate()){
  Serial.println("Activad");
  //Add code to run if it works
 }else{
  Serial.println("Clave Errónea");
  //add code to run if it did not work
void loop(){
  char key = keypad.getKey();
  if (key){
 switch (key)
          case '1':
          lcd.clear();
          lcd.print("Ajustes");
          case '2':
          lcd.clear();
          lcd.print("Activ");
          case '3':
          lcd.clear();
          lcd.print("Mem");
          case '4':
          lcd.clear();
          lcd.print("Err");
           case '5':
           keypad.getKey();
           default:
           menu();
Cuando pulso 5 no me deja meter el password.¿Alguien sabe repararlo?
Un saludo, muchas gracias.
« Last Edit: October 23, 2012, 05:15:03 am by PascuaL » Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Es posible que
Code:
case !'5':
deba ser
Code:
case '5':
Logged
My homepage/blog: http://erwin.ried.cl
Alicante
Offline Offline
Sr. Member
View Profile
Ups, eso se coló haciendo pruebas.
Logged
Offline Offline
Newbie
View Profile
Hola buen día tengo una duda sobre el uso de la funcion set(password)
Quisiera saber de  que forma se puede cambiar el password que se define en el sktch por medio del teclado??
Logged
Pages: [1]   Go Up
Print
Jump to:
