Topic: Control arduino from your webserver with java mobile phone...as GPRS shield (Read 3225 times) previous topic - next topic
power7net
Hello!I make a simple application in Netbeans with Java2ME to control my arduino ( led on/off ) with my old java mobile phone Sony Ericsson W995 as gprs/3g shield.I believe work with all Sony Ericsson (JP-7,JP-8) http://en.wikipedia.org/wiki/Sony_Ericsson_Java_Platform and with all Java mobile phones if you send the correct AT command for connect with virtual port.My java code for phone is here ...
http://webgsmremotecontrol.webs.com/.You must need read first this : http://projects.sindrelindstad.com/how-to-led-arduino-php-proc/.For SE java here...http://www.bombus-im.org/docs/dg_java_me_r20a.pdf .
Web / sms / bluetooth / arduino / android remote control. Home Automation projects.
http://www.power7.net
power7net
Hello.My first test was with usb cable with my pc and PuTTY (COM 15 for me) with Sony Ericsson W995.Today open bluetooth PC and mobile phone and type AT*SEJCOMM=1,1 and work fine with bluetooth without cable.I use BlueSoleil Serial Port Services.I believe i can use my phone as BT shield for communication with more arduinos BT.(Network with arduino BT).My or your phone has GPS,camera,motion sensor,clock,calendar,sd card,voice,audio,sms,mms,e-mail ... with suitable program javame can work these.Thanks.
dxw00d
Is this a question, or a statement?
Please don't crosspost - http://arduino.cc/forum/index.php/topic,128185.msg965895.html#msg965895.
power7net
Software: I use for java2me HttpConnection interface and CommConnection interface.For arduino code you must use serial and AT commands.
Hardware: Connect arduino serial Tx,Rx with  mobile phone cable...example with old sony ericson k700.For new phones example SE W995 you must use usb shield...
Read Google : Arduino serial connect usb mobile phone...Another option is connect with bluetooth...working on these and i will have the solution (java and arduino code) soon.Thanks.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
