Reading, Berkshire
Offline
Full Member
« on: October 18, 2012, 09:40:46 am » |
Hi, I'm running an UNO with an Arduino Ethernet shield and a sparkfun color LCD shield.
When I use a 12V, 2A, center positive power source it resets itself every once in a while and gets very hot.
When I use a 9V, 300mA, 2.7VA , center positive power source it doesn't power the screen properly.
I am wondering if using a USB power adapter will make any difference.
What power supply would you recommend?
Thank you.
Logged
Reading, Berkshire
Offline
Full Member
« Reply #1 on: October 18, 2012, 09:48:30 am » |
Logged
Reading, Berkshire
Offline
Full Member
« Reply #2 on: October 18, 2012, 10:02:55 am » |
 one of these USB plugs and a normal usb cable got it working, I'm just wondering what power adapter I should use.. In case I ever need to use the USB for something else.
Logged
Valencia, Spain
Offline
Edison Member
« Reply #3 on: October 18, 2012, 10:04:33 am » |
 one of these USB plugs and a normal usb cable got it working, I'm just wondering what power adapter I should use.. In case I ever need to use the USB for something else. Presumably something that can supply less than 12V and more than 300mA.
Logged
Norfolk UK
Offline
Edison Member
« Reply #4 on: October 18, 2012, 11:39:25 am » |
Maplin L67BQ 9V 600mA £11.99 L46BL 9V 2.25A £19.99
Logged
Offline
Edison Member
« Reply #5 on: October 18, 2012, 11:41:54 am » |
When I use a 12V, 2A, center positive power source it resets itself every once in a while and gets very hot. In that set-up, if you need more than 200ma, I would seriously question if something is wrong.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #6 on: October 18, 2012, 06:34:43 pm » |
When I use a 12V, 2A, center positive power source it resets itself every once in a while and gets very hot. In that set-up, if you need more than 200ma, I would seriously question if something is wrong. Not sure what point you're trying to make. Ethernet shields take 150mA or more, and the LCD probably needs 75mA or more, and Arduino 40mA, all adds up to more than 200mA - hence the excessive heat from 12V leading to thermal-shutdown of the on-board regulator. Solution is either good USB PSU, or 7..9V supply to the barrel jack, or even a DC-DC converter (good choice for vehicle as supply is 12V anyway)
Logged
Valencia, Spain
Offline
Edison Member
« Reply #7 on: October 19, 2012, 03:19:56 am » |
PS: What does this have to do with the UK? I'm intrigued by the mental leaps needed to come up with the question.
Logged
Nice, France
Offline
Full Member
« Reply #8 on: October 20, 2012, 04:25:06 pm » |
DC is different in the UK  although the third post did show a standard UK mains plug (yes, they really are that big, rated 240V and 13A).
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #9 on: October 20, 2012, 06:09:57 pm » |
Because a PSU has to match the mains voltage of the region its used in? 240V 50Hz in the UK.
Logged
Nice, France
Offline
Full Member
« Reply #10 on: October 20, 2012, 08:10:49 pm » |
and France and Germany and Italy and Switzerland and Sweden and
Logged
United Kingdom
Offline
Faraday Member
« Reply #11 on: October 21, 2012, 08:14:25 am » |
How do you have the LCD backlight connected? I don't normally power LCD backlights from the +5v supply, I power then from the incoming +9V or +12V supply through a series resistor. That way, the current taken by the backlight doesn't heat up the regulator, and it's less likely to go into thermal shutdown.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Valencia, Spain
Offline
Edison Member
« Reply #12 on: October 21, 2012, 09:16:42 am » |
Nope. It's been 230V for quite a long time now (since 1983 I believe...) - to harmonize with Europe.
Logged
