Author Topic: 7 Segment display - help.  (Read 370 times)
Oz
Folks, my old books are no longer valid.
They have chips in them which aren't available and there are new chips which aren't listed.
I want a BCD - 7 segment display driver.
I am going for a 4056.
I hope that drives "common cathode" displays.
Of course the next problem is (though I think I have nutted it out) the 7 segment display I have.
It has 4013 stamped on the side of it.  It has 10 pins.  Counting them the way you do an IC, I have determined:
1 - cathode.
2 -> 5, 8 -> 10 are the display and 7 is the RIGHT decimal point.
Pin 6 doesn't seem to be used though there is a LEFT decimal point.
I guess if running on 12v I will need 150 ohm resistors between the 4056 and the display?
Now, More Than Ever
There's no hoping in electronics.
A 4511 will do for common-cathodes.
http://www.doctronics.co.uk/4511.htm
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
4056 - I think that chip is specially for LCDs rather than LEDs - you need a higher current output for LEDs, the 4511 is one I used in a previous universe(!) for common-cathode displays.  Latches and does bcd -> 7seg
Oz
Yeah, sorry as I think I said, my "data books" are from the 80's.
Shall have to look around a bit more.
So I shall be using a 4511.
« Last Edit: October 20, 2012, 06:13:58 pm by lost_and_confused » Logged
The "4013" marking might be related to a Fairchild FLB4013X1 - 2" by 1.2" large 7-seg display with 4 digits?  The best my web search found.
